LG 55LM4600 faulty LED Driver or Backlights?
  • tvfixer007
    • Feb 2015
    • 86
    Any idea what the cause of this could be? I have a dark spot on the right side of the screen. When I go to the menu and turn screen off, and then press a button on the remote to turn screen back on the dark spot is gone for 5 seconds. Every time I do that the dark spot goes away for 5 seconds and comes back.
    I originally presumed it was a bad LED.... but it doesn't make sense to me that it would work for 5 seconds then stop!?
    https://www.youtube.com/watch?v=dUi1...ature=youtu.be
  • JeffJ
    • Apr 2012
    • 189
    Re: LG 55LM4600 faulty LED Driver or Backlights?
    This is an edge lit tv and its clearly one of the banks of edge lighting failing. The fact it works for a few seconds is weird.
    If i had to guess that bank on the right side has a dead shorted led and the PSU is shutting down that PWM bank when it detects abnormal draw.
      It does look like some LEDs in that section shorted out so the circuit goes into over current shutdown.
      • tvfixer007
        • Feb 2015
        • 86
        Was hoping it wasn't bad LEDs. Kind of figured it was but I thought if LEDs are shorted they don't work at all.
        I'm going to take the panel apart when I wake up in the morning and test all the LEDs.
          LEDs are connected in series to form LED strings, there may be 4 strings of LEDs used in that panel, so if some are shorted out the rest if the LEDs in that string will still light up, like Christmas lights..
          • CapLeaker
            Leaking Member
            • 8158
            Looks like an LED failure to me too...
            • tvfixer007
              • Feb 2015
              • 86
              I took out the strip and tested the LEDs one by one with a battery. They all lit up and were relatively close in brightness. Also in the attached image if I touch my meter probe or any metal tip on the PDIM and PDIM2 (J47, J44) jumpers the backlights flicker.
              Leaving the TV on for a while the left side LED strip starts acting up in the same manner. Which is really confusing me. Why would the other LED strip start acting up much later?
              When that first section of LEDs cut off, they are actually still on with a very faint glow coming from them.
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                I would have plugged the strip back in and let the tv drive them,that way you could see them fail after a few sec. Battery testing them prob didn't trigger the defective one.
                Proud owner of dozens of broken TV's and many,many,many boards.
                Our website and passion:http://hollenhundshepherds.com/
                • DOPPLERBOB
                  • Nov 2012
                  • 12
                  • usa
                  It's most likely an LED failure at full operating current. The battery test is good to weed out open or shorted LED's, but it really doesn't test the LED's under normal operating current and after they heat up. I had the same problem. I operated the LED's normally with it taken apart so I could watch. I sped up the process by using a hair dryer on the suspected defective area. One LED would open up and the whole strip of 6 goes out (in series). Turned out to be a bad solder connection to the LED.
                  • CapLeaker
                    Leaking Member
                    • 8158
                    Plug the LED's back in, put your DMM to DC V and probe each LED string while turning the TV on. That will give you a clue on which string the problem is. LED's can fail like that. They may work for 5 seconds or even 5 or 20 minutes then go out. You can try to turn the back light down to next to nothing and probably the LED will stay on longer.
                    • tvfixer007
                      • Feb 2015
                      • 86
                      I realize now how stupid I am! I found the bad LEDs but these things are way too hard to remove! So I'll be ordering new strips instead, and I'll post my final result when I get the TV back together.
                      • CapLeaker
                        Leaking Member
                        • 8158
                        Sounds like a plan...
                        • tvfixer007
                          • Feb 2015
                          • 86
                          we're sorry to inform you that one of the LED strips you purchased has been damaged during shipment. We shipped the items out yesterday and USPS brought the package back this morning only for us to see that the strips had been damaged beyond repair. At the moment we only have one strip left to be able to replace and that is the Led Backligth Strip LG 55LM6200 6922L-0003A 6920L-0001C 6916L0782A (strip and holder) #L0003A. We can refund you the complete cost of the other LED since we cannot replace that one at this time, but we can still ship out the 6922L-0003A. If you would like us to ship that part out, please let us know and we'll refund you the cost and ship it out again today! We apologize for any inconvenience this causes you and we hope you understand.
                          Thank you
                          Michael Barriel
                          MBS Electronic Inc. & MyShopTV
                          So much for fixing this TV. I found 2 strips for $32.99, and they said one got damaged in shipping. The one I really needed. Only had to be shipped from Miami to Tampa. Find that kind of odd really.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Don't think they are that hard to replace with heat gun or iron. You could buy strip and replace bad led's with it.
                            • CapLeaker
                              Leaking Member
                              • 8158
                              Maybe use Reeceyburger's stacking method. There is a video from him on youtube about that.
                              • tvfixer007
                                • Feb 2015
                                • 86
                                These edge lit bars are hard to repair. I messed up the tracing somehow. Just decided to replace both of them with good LEDs. TV is now working great, thanks everyone!
                                • osrex
                                  LED DRIVER KEEPS DYING
                                  by osrex
                                  Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                  i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                  i have no datasheet at all for the LED lights, all i have is its length.
                                  long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                  as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                  05-05-2025, 03:36 PM
                                • bafangrider
                                  Faulty LED floodlight driver
                                  by bafangrider
                                  Hi All,
                                  First post here.
                                  Got a LED floodlight that filled up with water and am trying to repair it.
                                  Steps taken;
                                  1. Cleaned up all water and plugged in to test function
                                  2. Driver board with no load spits out around 85VDC
                                  3. Soldered LED back on and the LED flashes straight away
                                  4. Also noticed one led on one of the rows was faulty causing the row to stop working - shorted that LED and now the row works
                                  5. After doing this the LED seemed to work be then flashed after about 5 mins of use
                                  6. Then went over the board and re-soldered all connections on the
                                  08-21-2022, 11:05 PM
                                • Spongebob89
                                  LCD Backlights Driver - Unknown Component
                                  by Spongebob89
                                  I have an "LCD Backlights Driver" and it is not working. After measurments and checking the routes of the PCB I beleive that this component on the red circle is a choke for filtering the supply voltage and block noise from the inverter to go back to the main board. When I measured in ohm and in diode mode with multemeter shows always OL. I shortcircuit this component and it worked. The current that I measured with multemeter is 550mA, so I want rated current 1,5x550mA=825mA~1Α. Am I right that this is a choke and if yes what value do you beleive is (maybe 15uH or the...
                                  07-22-2023, 02:59 AM
                                • howardc64
                                  Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                  by howardc64
                                  Problem
                                  Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                  Model & Board Pics
                                  Conflicting Spec
                                  Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                  https://www.shopjimmy.com/vizio-gj-2k1...
                                  10-10-2024, 01:16 PM
                                • charif
                                  Audio Driver for Thomson P14C4BK128
                                  by charif
                                  Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                                  I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                                  The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                                  Here are the details:
                                  • Model: Thomson P14C4BK128
                                  • Operating System: Windows 10 64-bit
                                  If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                                  Thanks in advance for your help!
                                  04-30-2025, 05:41 PM
