AKAI CTV29TA weird standby
  • sausagejohnson
    • 20
    Re: AKAI CTV29TA weird standby
    @petehall347 gosh a crt of that era is even before my time!
    @R_J, yes the ICs match a few on both of those schematics, and the RCA/SuperVHS panel matches both.
    I've saved both those out for future reference.
    • R_J
      • Jun 2012
      • 9532
      It looks like that base chassis is used for a few brands of tv, all with their own changes. Just google the chassis number and brands like Hyundai, Akira & Erisson show up. but no Akai service manual
      • Antony2023
        Monitor making weird noise when charging resolution or in standby mode
        by Antony2023
        Hello, guys i need some help, i have an old fujitsu siemens LCD monitor, and is making weird noise when is changing resolution or in standby mode.
        I open it up, to see if it is any hardware damage, but i only see 2 capacitors bulging on the logic board, i'll probably change them. On the power supply circuit board, only one thing caught my attention, the transformer seems to have leaked something out of it and the mess around it. Do you think there may be a problem here?...
        01-07-2023, 09:24 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • fharris1977
        Vizio D50u-D1 Dead Set No Standby
        by fharris1977
        Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
        12-28-2023, 10:25 AM
      • tony359
        Faulty CRT AKF12/Philips CM8500: bad flyback?
        by tony359
        I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
        What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
        There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
        Can it be a short somewhere...
        08-22-2023, 04:39 PM
      • Crystaleyes
        Samsung BN44-00259A standby question
        by Crystaleyes
        Hi all.
        I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
        SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
        Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
        The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
        08-11-2023, 05:15 AM
