Vizio SV320XVT no video no sound
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    #41
    Re: Vizio SV320XVT no video no sound
    There's no obvious signs of damage ie burnt components so the only thing left is to use your meter to test the components, diodes, mosfets and resistors and see if anything shows up as faulty.
    Perhaps a replacement inverter at this point as suggested by Vinceroger is not such a bad idea. If the replacement works then great if not you probably have a CCFL tube fault. You could then sell on the replacement board.
    • ruben53
      • Sep 2015
      • 37
      if a invertor board is cheap i would probably try another one then if still having the same issues it may need replacement ccfl tubes you can always re sell on the invertor board if it does not fix the issue.
      This inverter board was difficult to find,in every place was sold out,finnaly found
      one and ordered it.Lets see when it arrives and install it.
      I want to thanks all of you that helped me in this project.:
      Beers for everyone.
      • RonEckler
        All the posts I have found here are fairly old posts. I don't see anything that has resolved the issues with this model of TV. I do have this model I am just playing around with right now, and as all the TV's with sv320xvt/sv370xvt seem to have the same issues. I have tried to reach out to Vizio for a schematic, but the cost of the schematic isn't worth the price of this set. I have noticed that the 0z9966sn chip on the inverter board will shut down if the florescent back lights are faulty. Try finding those are impossible, so I am looking at retrofitting LED back lights on the tv. If I have any luck I will post the solution.
          • 12206
          • U.S.
          #44
          One of many conversion videos on youtube, probably easiest method is grab a universal kit from aliexpress or somewhere, they're like 20 bucks or less, comes with the driver and led strips: https://www.youtube.com/watch?v=q4C_pB10nlo
          • RonEckler
            Thank you for the information. I will definitely check out the YouTube channel too.
            • ajshoe
              vizio E60-E3 backlights, sound, no video
              by ajshoe
              Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
              Does this mean remove right side (from front of TV) tabs ?
              Like a second opinion before possibly destroying set....
              04-07-2023, 01:59 PM
            • soeren
              A2442 - No sound over internal speakers and no video playback
              by soeren
              I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
              All happened after the battery ran out of power overall several days when I was on vacation.
              I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
              07-26-2024, 01:24 AM
            • JRade
              Audio video receiver KENWood KR-V990D,no sound
              by JRade
              When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
              The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
              I replaced the capacitor C303/0.047F, nothing changes.
              I'm asking for help, what should I do next?
              Thanks in advance!...
              08-05-2025, 10:23 PM
            • FrancescoV
              Onkyo HT-R390 no sound output, video output ok
              by FrancescoV
              Good morning everyone,
              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
              The firmware reported is the following:
              M:1.00/11107BLP
              D:?.??/????????
              O:1.00/11107AL
              The DSP firmware given the question marks seems corrupt.
              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
              05-11-2025, 02:59 AM
              HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
              This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
              09-12-2024, 02:00 PM
