Samsung 32" inverter MOSFET Overheating problem
  • suprex
    • Oct 2015
    • 10
    • Serbia
    I have Samsung LE32C450E1W with backlight inverter problem, so everything works just no backlight. Inverter is VIT70097.00 REV 2, and it's powering four CCFL's that are in the form of elongated letter U.
    The inverter itself hadn't MOSFET's on it, all four of them were removed by someone before me. So I googled and found out it uses two N channel and two P channel fet's, P2904BD as N channel and P4004ED as P channel, as a replacement I use AOD 4184a and IRFR 5305 respectively, and everything works, but one P channel FET is geting way to hot (three others transistors are cold). I followed the gate line of the P channel FET transistors and all resistors and diodes are fine, but I noticed that the parts are not the same, ie. different resistors values. They hadn't been changed I know that because I compared with other images on the internet and everything is the same as on my inverter, but I do not understand why. By the way, the inverter has two IC: OZ 964AGN and CP 1099.
    So my main question is why this transistor heats up?
    Thanks in advance and Happy new year.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung 32" inverter MOSFET Overheating problem
    Have you compared the secondary and primary resistances of all the 8 transformers. Perhaps one of them is faulty and causing the heating up.
    • suprex
      • Oct 2015
      • 10
      • Serbia
      Yes, i did check all them, all eight primers are connected in series and each one have 0,1 Ohm resistance, secondaries are about 384 Ohms +-5 Ohm.
      • CapLeaker
        Leaking Member
        • 8326
        maybe the lamp is drawing too much current?
        • suprex
          • Oct 2015
          • 10
          • Serbia
          Can I measure it with regular DMM? I'm asking this because of high voltage.
          • CapLeaker
            Leaking Member
            • 8326
            nope. all you can do is change lamps around and see if there is a different mosfet is getting hot.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Could also be dry inverter caps. Test them for esr.
              • jetadm123
                • 2169
                When you say the resistors and diodes are fine, did you actually measure their values or do they just "look" okay?
                • suprex
                  • Oct 2015
                  • 10
                  • Serbia
                  I will try switching lamp places.
                  I do not have ESR meter. Is there other way to test them, except with ohm meter, for short?
                  I measured all the resistors, and for the diode first i unsolder it, and then test them.
                  • suprex
                    • Oct 2015
                    • 10
                    • Serbia
                    I found solution for overheating. The problem was in P channel replacement FET's. When a low voltage is applied to gate, the drain- source resistance is a bit high, causing FET to heat abnormally. Anyway thanks for the help, I hope this will help someone with similar problem.
                    Cheers.
                    • petehall347
                      • Jan 2015
                      • 4439
                      • United Kingdom
                      why was the voltage low ?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        So how did you fix that ?
                        • suprex
                          • Oct 2015
                          • 10
                          • Serbia
                          The gate voltage which comes from ic goes trough resistors and diodes is ok, but is insufficient to fully turn on the replacement P type FET so the rds-on is a couple of Ohms, and from there the temperature goes high.
                          Sorry, I forgot to write that although that was my intention. I replaced those P channel FET's with P4404ED (very hard to find in my country), and everything works great without overheating. Other option was to change values of the resistors to match the IRFR5305 FET, but the first option was easier and safer.
                          • petehall347
                            • Jan 2015
                            • 4439
                            • United Kingdom
                            so the conclusion is you chose poor substitutes to start with ? i am learning about fets too myself . even though i have replaced many in the past with like for like .. my head is at bjt mainly .
                            • suprex
                              • Oct 2015
                              • 10
                              • Serbia
                              Yes, the first substitute was not equal...
                              I also replaced a couple of fets in past with similar ones and most of those was easy fix, this was a little to think over.
                              • petehall347
                                • Jan 2015
                                • 4439
                                • United Kingdom
                                well done .. i must have read same article as you recently as i am just learning about these power supplies . i remember same thing about fets needs to be switched on hard to work properly .
                                  http://www.microsemi.com/document-po...osfet-tutorial
                                  https://cdn.badcaps-static.com/pdfs/...19d1be1cc7.pdf
                                    09-07-2024, 05:50 AM
                                  • dj8452000
                                    How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                    by dj8452000
                                    I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                    02-18-2025, 08:28 AM
                                  • tmaster21
                                    Ideapad 100 NM-A841, P channel mosfet on laptop in.
                                    by tmaster21
                                    Hello guys. i'm having problems here with this lenovo 110 with board NM-A841 laptop. There is an P channel(pq302) and after it i start ,i have 19v but with time, it decreases or if i press "power on" switch or jumper j6 , it falls to 0 and back to 19v. There is no short and works good on battery, but won't charge or charge until the voltage drop like i explain after P mosfet.
                                    Well i suspect that this mosfet is no good. if you look to skematic i have steady 19v on P2 but start to decrease on P3 like if the mosfet is dying . the gate of boot N an P mosfet are the same: is steady...
                                    07-17-2023, 09:48 AM
                                    09-06-2024, 11:40 PM
