Solarized Samsung LN37A450C1DXZA
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Solarized Samsung LN37A450C1DXZA
    Originally posted by jbjsabu
    I wish I could pin down where this set's problem lies. It seems like there should be a better way than just swapping out chips and boards willy-nilly.
    I guess I will wait for my replacement AS15 to come in and and see where it goes from there.
    Thanks for the looks and consideration.
    You haven't swapped a board and you're not replacing a chip willy-nilly.
    It's been suggested by several people with many years collective experience.
    Solarized image of some or all colours, dark image, double image all points to the gamma ic in this case its the common to fail AS15.
    They cost so little and take less than 5 minutes to replace with the correct tools, I don't even bother to test them. I've replaced over 2 dozen in the last couple of years and I've been right with every one.
    If you only have a soldering iron and not hot air, I suggest using some ChipQuick to help you remove the old one.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      +1 willy for sure
      • jbjsabu
        • Oct 2013
        • 31
        • usa
        Originally posted by ReeceyBurger123
        +1 willy for sure
        LOL
        I replaced the AS15 and it looks like a fix!
        I appreciate you all sharing your experience with me, for sure.
        Thanks for the ChipQuik tip, too. Easy off, and not _too_ hard soldering the new one back on. (Note to future self: when ready to solder new ic, hide the ChipQuik from reach.)
        By the way, any idea where these "clips?" would fit back on? I originally opened the back with the set vertical and they just tumbled out.
        Best regards!
        • ducky29
          • Dec 2015
          • 369
          • Europe
          Best regards!
          They keep the metal frame and the plastic frame together
          • scottmet
            • Jan 2015
            • 38
            Try this video might help solve your issue best of luck.
            https://www.youtube.com/watch?v=c-aXKCTiU6I&t=213s
              • 12274
              • U.S.
              #26
              Quick tip:check date of last post.
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • ohren
                by ohren
                09-08-2023, 05:24 PM
                09-07-2024, 05:50 AM
              • Nicktronic
                Samsung Power Supply Board BN44-00874F
                by Nicktronic
                Hey everyone,
                This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                Anybody...
                03-17-2025, 06:20 AM
