42"Fluid plasma tv Mod#(Samsung)pn50b550t2f
  • rich-t
    • Dec 2016
    • 70
    Re: 42"Fluid plasma tv Mod#(Samsung)pn50b550t2f
    Ok, put my original board in. All were pretty close ( 0.1 ohm) except for 1 SE8117TA on pin 1 = 2.05v and new(?) one was 1.25 . Also 1 of the 1084PM reads different, pin 1 now =0v 2= 1.25v 3=2.50v . Very different from replacement but neither works, at least the new one allows me to turn it on with the remote as my old one did until I touched something wrong :-( I hope someone can help me. My coffee table still full of TV,
    • rich-t
      • Dec 2016
      • 70
      BuMP?
      • rich-t
        • Dec 2016
        • 70
        bump
        • vinceroger69
          • Mar 2012
          • 6714
          #104
          what boards have you got left maybe change back to the origanal psu and lagic board and just keep the replacement main board in just incase one of your replacements are faulty in someway to.
          • rich-t
            • Dec 2016
            • 70
            Hey thanks for the reply I'm going to resolder some of the replaced caps on the main board, they look pretty bad, then put it back in if no joy I'll try the psu then logic. Don't know what else to do at this point.
            • vinceroger69
              • Mar 2012
              • 6714
              #106
              so was your replacement mainboard repaired before you got it? the trouble is if you do any work/repairs on it they may not have it back as a return if is faulty.
              • rich-t
                • Dec 2016
                • 70
                Broke a pin on a plugin on the replacement board##@#$$%^ I'm now going to have a LARGE VODKA. Make a jumper maybe tomorow.
                • rich-t
                  • Dec 2016
                  • 70
                  Well I bit the bullet and ordered another main board today.My clumsy fingers are costing me but I am determined to fix this bugger even tho I am getting close to the cost of a new LCD, but they dont hold a candle to this plasma. Wish me luck, I,ll let ya all know..
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #109
                    your as bad as me never give up on a project even if it costs more than its worth but intermittent faults like this are always going too be hard to find thats the trouble with secondhand boards you never know if there 100% working or adding a diffrent fault for you to find as you have said your self you have now changed 3 boards so which one is now at fault i would try putting your old boards bk in and just change replacement mainbaord and go from there if for some reason that does not solve it go back to the start ie psu voltage testing make sure all are correct (may have to add resistors to jump start psu) then if psu ok run test patterns etc.
                    • rich-t
                      • Dec 2016
                      • 70
                      Hopefully new board here Wed. or Thurs. Then who knows :-)
                      • rich-t
                        • Dec 2016
                        • 70
                        Ah, the saga continues, after installing the 2n'd (new) main board I finally have a picture and a remote that will work with the tv,BUT, now I have no audio..It did work fine before. I originaly tested just hooked up to Air/cable and had a good pic. no audio so I hooked up my dvd which it played well before, no pic. white flash on screen, sometimes flashes "not supported" and of course no sound. Hooked it up to my fibre op and same result as with dvd. You fellas were right on about the main board. I wonder if you have an idea about this problem. The part no's match right down to rev.#
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #112
                          not sure about the audio issue just tripel check all cables are connected on the correct connectors im also not sure about the message your getting is there any firmware updates available for your tv maybe carry out a factory restore too
                          • martino
                            Not so "senior"
                            • Aug 2013
                            • 997
                            • canada
                            #113
                            go through all menus as well,a lot of tv's you can disable the tv sound for when you plug in an external sound device. Video settings don't match between dvd and tv? Is tv on 4;3 instead of 16;9 etc...
                            Proud owner of dozens of broken TV's and many,many,many boards.
                            Our website and passion:http://hollenhundshepherds.com/
                            • rich-t
                              • Dec 2016
                              • 70
                              Thanks for the replies guys I give those a try tomorrow, I'm too p/o'd tonight
                              • rich-t
                                • Dec 2016
                                • 70
                                I would like to hear from someone like Tom66 or Reeceyburger who have alot of experience helping newbies like me, to give me some guidance on how to go about diagnosing my no audio and no video on hdmi ports, pic. only on air/cable input problem. I really don't like the idea of orderiing a 3rd board.
                                Thanks Richard.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #116
                                  Speakers connected properly ? If so return it and order another.
                                  • rich-t
                                    • Dec 2016
                                    • 70
                                    Alas I seemed to have all that's available for this oddball.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #118
                                      did you manage to try a factory reset ?
                                      • rich-t
                                        • Dec 2016
                                        • 70
                                        Ok guys, problem solved, found pinched speaker wires, works fine now.
                                        Thanks to all who helped me grope my way thru.
                                        • sajjadalisw@yahoo.com
                                          • Jan 2017
                                          • 15
                                          • uae
                                          #120
                                          thanx
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
