Vizio E390I-A1 No picture, has backlights.
  • SHADOW3277
    • Jun 2014
    • 123
    Picked up this TV that turns on, has backlights but no picture. There is no seperate TCON.
    I figured a bad main and ordered from shopjimmy. They were only selling the complete repair kit and not the main board by itself. I replaced the main, still had the same symptoms. Replaced the LVDS cable with no change. Went ahead and put the power supply and led driver boards in (because why not?) and I still have the same symptoms.
    SJ sent me another kit thinking the main was bad in the first one. Received it and still have the same symptoms. The only thing I can think of is that I either received 2 bad main boards or I have a shorted panel. But I have never seen a shorted panel in a TV this small and wanted to get some advice. TIA
    Re: Vizio E390I-A1 No picture, has backlights.
    Pictures of what we are dealing with?
    • SHADOW3277
      • Jun 2014
      • 123
      Sorry, I meant to post these when I started the thread
        Need straight shot pictures of the main board around the LVDS connector so we can see if there is 12V going the panel or not. There may be a fuse on the panel PCB also.
        • SHADOW3277
          • Jun 2014
          • 123
          Here is a pic of the main from SJ. My camera does not do close up pics clearly.
          Here is the link as well - https://www.shopjimmy.com/vizio-cbpf...r-e390i-a1.htm
          I'll also check the panel pcb for a fuse. I am at work now so I won't be able to check until tomorrow.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Your Lcd panel is one Ive had issues with before, you see the ribbon cables that link the Lcd driver boards give them a reseat see if it works.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              • SHADOW3277
                • Jun 2014
                • 123
                I reseated the ribbon cables with no change. Still have backlight, no picture.
                I also checked for a fuse on the panel PCB and did not see one.
                  It looks to be that Q104 by the LVDS connector is the switched MOSFET for supplying the VCC to the TCON, so check the MOSFET Q104 pin 5 (5~8 are all connected together) to see if it has 12VDC output or not when TV is ON.
                  BTW, do you have good clear picture around the LVDS connector on the LCD panel so I can see if I can locate the SMD fuse.
                  • SHADOW3277
                    • Jun 2014
                    • 123
                    Here is a close up of the LVDS. I'll have the readings shortly.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Fuse as show. With set off check using your meter set to ohms and probes on each side that it measures 0 ohms
                      Then with set switched on and meter set to dc volts, measure what voltage is on the fuse. Red probe on fuse, black on chassis.
                      • SHADOW3277
                        • Jun 2014
                        • 123
                        Sorry for the delay, been a little under the weather.
                        On ohms I get 0.6
                        I get 12.4 volts at the fuse with the set on.
                        • Diah
                          • Feb 2013
                          • 6384
                          i didn't read any things about the sound.. did you have sound ???
                          • SHADOW3277
                            • Jun 2014
                            • 123
                            It had sound.
                            • Diah
                              • Feb 2013
                              • 6384
                              Originally posted by SHADOW3277
                              It had sound.
                              Fuse are okay and volts okay too, you need to release the LVDS socket from panel TAP and inspect first the socket pin, clean.. also need to release the TAP from the chassis to inspect the back side of it if there burn or cut ) break. same way to the ribbon between LCD and TAP. its look no feed go back from Panel to the MB
                              • SHADOW3277
                                • Jun 2014
                                • 123
                                Ok, on pin 5 of Q104 I have 12 volts.
                                I cleaned and reseated the LDVS cables with no change. (I cleaned both of my cables and tried both again with no change.)
                                I checked the panel PCB and did not notice any burnt spots.
                                • SHADOW3277
                                  • Jun 2014
                                  • 123
                                  So I am guessing it is the panel that is bad somehow since everything else checks out?
                                  Should I just write this one off and take it to the recycling center?
                                  • gavric
                                    Vizio M70-C3 Half picture is bad, main board on its last leg?
                                    by gavric
                                    Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                    When tv powers on vizio V logo shows nice on whole screen. picture 1
                                    When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                    When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                    When i click video to start playing picture goes black(like when you change...
                                    09-02-2021, 08:55 PM
                                  • Awsmessymail
                                    Vizio E701i-A3 backlight only and now no backlight
                                    by Awsmessymail
                                    Hello all,
                                    I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
                                    I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
                                    As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
                                    02-13-2024, 11:04 PM
                                  • mrtek
                                    Vizio M65-C1
                                    by mrtek
                                    Hi.
                                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                    07-14-2025, 07:28 PM
                                  • csmith
                                    Vizio-D50u-D1 Pulsating Backlights
                                    by csmith
                                    This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
                                    Am I looking at a defective strip? Thanks in advance.
                                    11-07-2024, 02:56 PM
                                  • spice_disc
                                    Vizio TV M50-C1 reboot cycle and static on screen
                                    by spice_disc
                                    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                    09-08-2024, 02:37 PM
