Samsung PN59D6500 power cycling where to start?
  • pbiancardi
    • Nov 2016
    • 20
    Just got a cheap PN59D6500 on Craigslist, seller described as power cycling and non responsive. I got it home and it worked fine, was able to play a movie start to finish from built in Netflix app. I also updated the firmware to 0018 (shortly after this the power cycling started, coincidence I'm sure since seller had an issue also).
    Now the problem presented itself to me, it shut off on its own and now just keeps trying to power on but doesn't.
    I have read that this model might be more likely to need a main board than a power board, can anyone tell me what I should start looking at first? Does the fact that everything worked fine for a couple of hours tell me anything?
  • sordids999
    • May 2013
    • 2158
    Re: Samsung PN59D6500 power cycling where to start?
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Maybe do some research on hoe to test Plasmas and Pson voltages.
      • pbiancardi
        • Nov 2016
        • 20
        Here you go, I don't see anything bulging.
        • vinceroger69
          • Mar 2012
          • 6714
          I would check the power supply maybe resolder all the parts/components on the heatsinks and check for any bad/cracked jpints on the rest of the board then carry out the tests in the video and leave running on the test patterns does the tv still shut off at the same time period?
          https://www.youtube.com/watch?v=JjrwTZC5nVg
          • pbiancardi
            • Nov 2016
            • 20
            I tried resoldering but it doesn't even get to standby mode, as soon as i plug it in it tries to power and and starts cycling?
            Honestly I am capable of small repairs but probably not troubleshooting, what board seems like I should try swapping first, the main or power? It's very likely ome of those correct?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Seems to me like a mainboard issue, like corrupt firmware or bga solder. Please test what voltages I have asked you to. Including with the set working and when it fails:
              Vson
              Pson
              Vs
              Va
              • pbiancardi
                • Nov 2016
                • 20
                Vson
                Pson
                Vs
                Va
                Pson goes from near nothing to 3.28
                Vson also goes from zero to 3.28 while power is trying to turn on
                I don't seem to get anything from VS or VA but realize TV never actually powers on its cycling the entire time.
                Sorry meter set wrong va is 55 and vs 190 at a certain point in cycle.
                Va stays consistent vs spikes at 194 then drops to zero. This is all while TV is cycling, it never kicks on.
                • pbiancardi
                  • Nov 2016
                  • 20
                  If I jumper everything and try to get the test patterns all I get is a blank screen, also at this point VS is zero??
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Your sustain boards are shorted. Remove the Ysus connector and Xsus then measure for short circuits on the power transistors.
                    • pbiancardi
                      • Nov 2016
                      • 20
                      Isn't there a test to unplug one at a time to narrow down which board to look at?
                      Is this worth fixing?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        No, helps if you search the forum on how to test Plasmas. These sets if it detects Vs is not loaded or is being heavily stressed (due to short) it turns vs off. Worth fixing though as these look good when they work. Also you should test the sustain voltages like Vsc and Ve on the sustain boards.
                        • pbiancardi
                          • Nov 2016
                          • 20
                          Ok I'll do some reading and check back in once I do as you said thanks.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Ok cheers, let is know what voltages you get.
                            • pbiancardi
                              • Nov 2016
                              • 20
                              Ok still not certain I am doing it correctly but when I test the two outer pins on the transistors of the first board I removed, all readings are basically the same (about 10 when the ohm scale is set to 200k) except the two in the picture, one shows open line and the other is reading about 1/2 of the rest. Is this my issue (or at least an issue)?
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Does your meter have diode mode ? Its easier to find short circuits with that instead buddy.
                                • pbiancardi
                                  • Nov 2016
                                  • 20
                                  No but I can buy one, wouldn't what I did show those are bad?
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Transistors like that rarely ever ever fail open circuit. You could put the board back in though and test its voltages such as Vsc and on the other board on the right hand side of the screen (xmain) test Ve voltage.
                                    • pbiancardi
                                      • Nov 2016
                                      • 20
                                      I broke one of the ribbon cables that plug into the left side of the Y Sustain board, is that replaceable?
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        The ones going into the panel ?
