LG 32LE4500 LD01D - stays black no pic
  • wuffwuff2003
    • Nov 2015
    • 20
    • Luxemburg
    Re: LG 32LE4500 LD01D - stays black no pic
    After another test: I take out R157 , first resistor after IC101 , Resistor between PWM2 and PWM_DIM. 100 Ohm = OK. Without the resistor the PWM2 line has 3,2V. I think this a big Problem on the Mainboard or may it be another board?
    • angel-boy
      • 550
      I have a 32LE4500 , the led si red , white, and dead, no respond to power button, any idea ?
      • angel-boy
        • 550
        any help ?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Have you taken any voltage readings off your power supply?
          • angel-boy
            • 550
            i order mainbord and power board, the help from forum comes with a delay , and the customer want faster repair
            • amsilva
              • 17
              • Portugal
              #26
              Does anyone know the solution for the problem in this thread?
              Is it the mainboard?
              • mmpi
                • Mar 2022
                • 8
                • Malta
                #27
                Hi all, i have the same problem. Power led red, then white but no picture. Measuring voltages IC1002 is not giving the ok for the inverter board and t-con board. Other voltages seem to be ok. There seem to be no error signals. Forced On the back lighting and all lit up well. Tried to reflow the processor but same result. At this point the tv is quite old and not worth is buying a replacement main board. If someone can give out some help, that would be great. Otherwise the tv unit is just scrap. Thanks
