LG 60PX950-AA sound, no picture - panel seems to "power up"
  • TehEkHo
    • Nov 2016
    • 14
    Hi all - looking for some help resolving an issue with my parents' LG Plasma - it's a 2010 manufactured LG 60PX950-AA
    Initially we lost HDMI inputs, which wasn't an issue as they never needed them, however, more recently it started to fail with sound but no picture, first, after around 30-60 minutes of viewing, but now the panel doesn't power up at all. Dad ordered and replaced a YSUS board, however, I have since come to understand that the old and new boards may not be compatible. I'm now looking for assistance in identifying and replacing the component responsible for the lack of video. I suspect it's related to power to the panel. I'm comfortable working with electronics, but my knowledge of TVs is limited to turning them on and changing channel
    Board IDs are as follows:
    PSU: EAX61432501/9
    CTRL: EBR70137601
    ZSUS: EBR63450501
    YSUS: EBR70503101
    Panel is a PDP60R1033
    I have placed the original YSUS back in place
    Va measures 60V on the test point on the PSU, which is in spec with the panel.
    Vs measures 203V on the test point on the PSU, which is in spec with the panel.
    While testing, I noted that the panel seems to be “powered up” - i.e., there's a glow on the panel which disappears as you turn it off.
    Any guidance would be appreciated
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 60PX950-AA sound, no picture - panel seems to "power up"
    You could of done some research on how to run the test patterns, quite obvious that this is a main board fault as the hdmis dropped out. Run the test patterns on the control board with the Lvds cable disconnected and let us know if you get the test patterns. If so replace the mainboard.
    • TehEkHo
      • Nov 2016
      • 14
      Good call - I couldn't access the information on running test patterns earlier - tried again now and got the picture showing the points to short.
      Have test patterns. Going to leave the set running for a while with them, but, looking at a main board replacement by the looks of things. May give the oven re-flow a trick if that's the case as it can't make matters any worse
      • mmartell
        • Oct 2013
        • 3189
        +1 nailed it.
        • TehEkHo
          • Nov 2016
          • 14
          OK, more info - on the test patterns, the TV switched itself off after a while - say 15 minutes - as in entered standby. I don't think that's normal, can anyone confirm?
          • TehEkHo
            • Nov 2016
            • 14
            So - managed to test that the main board was at fault by borrowing the one from my TV, now that it's out of storage (Long story). Correct diagnosis on the main board.
            Tried an oven re-flow - 8 minutes at 195C, and all is back to normal, which is nice as I couldn't find one available when searching.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Hmm maybe send it back ? Also I very very strongly suggest you remove the thermal pad off the cpu heatsink and replace it with thermal plaster and add a fan to the cpu if not same fault will happen shortly.
              • TehEkHo
                • Nov 2016
                • 14
                Yeah, good call on the paste at a minimum. My brother does have some thermal paste floating about, but I couldn't find it when I was putting things back together. I'll suggest the replacement of the thermal pad with paste when I speak to dad next, as well as said fan
                Heatsink was a pain the the butt to remove - the barbs that hold it in were troublesome!
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Ahh dam, also you will need thermal plaster not paste to glue the heatsink to the cpu Try and keep these Plasmas alive.
                  • TehEkHo
                    • Nov 2016
                    • 14
                    I managed to save the barbs - you think it's worth ditching the barbs and gluing it on regardless?
                    • Mad Capper
                      • Feb 2012
                      • 113
                      Did you use any flux on the main BGA IC under the heat sink when you re-flowed it? Anyone know if you explicitly should or should not use flux? If using flux do you need to clean it out after? How on a BGA, just flush it with isopropyl alcohol?
                      Did you remove the heatsink for the re-flow or leave it on? Any guidance on this?
                      Did you use a re-flow oven or just a regular home oven? How did you choose the duration and temperature?
                      ReeceyBurger123:
                      Would you get the power for the additional fan from somewhere in the set or use and external power supply? For additional cooling within the set do you have an idea how many fans you could run by taking power from the set without it causing a problem?
                      Thank You
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        A lot of fans are low voltage, low current. If you have a 5V or 12V supply on the set then find a fan at that voltage. Currents tend to be less than 200mA. I have one next to me 12V, 130mA.
                        • Mad Capper
                          • Feb 2012
                          • 113
                          Thanks. Good to know for future use.
                          Do you think adding cooling fans to plasmas with only passive cooling is beneficial? Such that the fans are exhausting out the top vents above the YSUS and ZSUS should one be able to get a fan in there.
                          • Nick's Tvs
                            • Jan 2014
                            • 621
                            Mad Capper, if your board fails again, let me know as we can perform a re-ball on it for you. The oven trick usually only works temporarily and is not a permanent solution even if the chip is soaked in flux. And yes a fan will help a lot as this is an issue with cracked solder joints under the main BGA chip caused by overheating.
                            • maneatingmonkey
                              Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                              by maneatingmonkey
                              I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                              There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                              03-27-2024, 07:17 AM
                            • EazyBone
                              Un70TU7000b Backlights work, no picture, has sound, panel shorted caps
                              by EazyBone
                              Picked up this Samsung above thinking it'd be backlights but it isn't. Now MAYBE I'll get lucky.
                              Found some shorted caps among the panel boards. Each cap along the line is shorted. On every board (3 panel driver boards)I disconnect each side right and left ribbons and they are no longer shorted caps and have about 1.5Mohm resistance (on left and right boards). The middle board has the main board disconnected and the caps are shorted. Last 4 pics show arrow to caps.
                              Now what exactly do I need to do in order to attempt to fix this issue?
                              do I have to take each one...
                              12-24-2023, 06:59 PM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • stylishconsultant
                              un60j620dafxza - Samsung No Display Problem
                              by stylishconsultant
                              Hi All,
                              Need help.
                              I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                              So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                              problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                              might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                              09-04-2024, 03:26 AM
