LG 60PA6500 Mainboard
  • Jsikora
    • Apr 2016
    • 64
    Have a 60PA6500 with no power. When plugged in I get 1 click from relay and nothing else. Mainboard has solid red light and front panel too. If the main is disconnected it will power on and I can see light on the screen and the logic board will then flash green (not the main). I pretty much assume bad main but was wondering if there were common problems with certain components on this particular board and if it is worth trying to save rather than $130 on another board. Any tips or help would be greatly appreciated.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 60PA6500 Mainboard
    Common issue with Lg mainboards...they are a pile of absolute fucking poor under-designed heaps of steaming dog shite Common issue on these is Bga solder issues on the Cup due to poor heat sinking give it a reflow could sort it.
    • Jsikora
      • Apr 2016
      • 64
      Already tried that and no luck. Was hoping there was a common component or so that was known to go bad...
      • Hamie
        • Apr 2014
        • 1383
        More than likely ic505.
        Ive already uploaded the dump for this ic for the 50" model. However it's for An EU board so probably won't work. Might be worth giving it a try.
        Alternatively you could try freezing the ic and see if it turns on. If it does you could update the software.
        • Hamie
          • Apr 2014
          • 1383
          https://www.badcaps.net/forum/showthread.php?t=54624
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
            by JDC
            ONN 100012588
            Issue: No Power, Then Rebooting After Main Board Change
            Short answer: replace main board and power board
            Technical answer: replace main board and Q306 & Q307 on power board.
            Long answer:
            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
