BA3AU0F0102_3 PSU transformer chirps every 2 seconds
  • fubr
    • Nov 2016
    • 9
    I have a BA3AU0F0102_3, a power supply that's usually found in Phillips, Magnavox, Emerson, Element, etc.
    My TV's particular model is ELEFW605, maybe that helps.
    I don't know the background of the TV - I found it by my apartment's dumpster practically new in box - still had all the styrofoam, and a bunch of the baggies that the cables come in. No receipt though! One man's trash is another's treasure, so I decided to try and fix it.
    I found this thread: https://www.badcaps.net/forum/showthread.php?t=48259
    But for most of that thread, I believe people were using the documentation for BA3AU0F0102_2 so there was a lot of confusion. The poster whose problem that users were solving also changed, so I think that thread has run it's course.
    I don't see any power LEDs or anything, and the power button doesn't do anything.
    The top right transformer (T601) chirps about every 2 seconds when all output wires are hooked in.
    When the ribbon cable (CN501) is removed, the chirping stops. It doesn't seem to matter if the bottom cable (CN1001) is plugged in or not (think it leads to the backlight?)
    I read somewhere that a transformer making a sound indicates that something on the output side of the transformer is acting up. I tested diodes by desoldering one end, lifting it, and using the diode testing feature on my multimeter.
    Good means they returned above 0.5, and a 1 in the other direction.
    D655: Good
    D653: Good
    D650: Good
    D1603: Good
    D1605: Good
    I also tested some of the components that they're selling in those 11-part repair kits.
    D601: Good | D602: Good
    D603: Good | D604: Good
    D605: * | D606: * (Pliers too fat. Tested w/continuity meter, aren't shorted.)
    D607: Good | D613: Good
    Q601: Good | R618: Couldn't test, DMM resolution isn't high enough for 0.22Ohms
    F602: Good
    There's also a troubleshooting page for the PSU on the manual (pg 32) and I tested some of those. I omitted the repeats. Lots of these are surface mount, so I didn't desolder them and only tested continuity:
    C625: Not shorted
    C665: Not shorted (this one is a ceramic, but I didn't desolder it)
    D617: Not shorted | D618: Not shorted
    D621: Not shorted | D623: Not shorted
    D664: Not shorted | IC601: Didn't test, but apparently must work or I wouldn't get voltages at the jumpers
    IC604: Didn't test, not sure how
    Was getting late - didn't get a chance to test these
    Q602, Q603, T601, R630, R631
    I also tested a couple of the jumpers at the top of the board while the ribbon cable was unplugged:
    P-ON+21V: ~13V
    AMP+13V: ~6.8V
    ALL+3.3V: 3.3V
    What is likely to be the problem, or where should I focus any component testing?
    Please assume I'm an idiot - I'm a recent grad in computer science, not anything electrical.
    Documentation:
    Schematic: pg 48
    CBA: Pg 66
    Troubleshooting: pg 32
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: BA3AU0F0102_3 PSU transformer chirps every 2 seconds
    I would check the 3 x diodes, 1 x zener and 2 x capacitors connected to Pins 10+11, and Pins 14+15 of T601
    • fubr
      • Nov 2016
      • 9
      Do you mean these?
      D650 Diode
      D653 Diode
      D655 Diode
      C651 Cap
      C656 Cap
      D654 Zener
        P-ON+21V: ~13V
        AMP+13V: ~6.8V
        ALL+3.3V: 3.3V
        Those are correct readings for the P-ON 21V and the 13V when the PS-ON is not present.
        You do not hear the chirp when the cable to the main board is not connected, right? If I remember correctly, some one found shorted cap on the main board.
        You need to have the boards all connected and then check the resistance between GND and each Voltage output pins to see if any one of them show very low resistance.
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          That PSU looks like it was laid out by a three year old on ritalin--They Really ARE havin' a larf at our expense aint they!!
          Appalling!
          The electronics design aint much better--Parallel diodes recipe for eventual self-destruction, just like Vestel turds, instead of a Single diode correctly rated for the job...
          TELEFIX
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Originally posted by fubr
            Do you mean these?
            D650 Diode
            D653 Diode
            D655 Diode
            C651 Cap
            C656 Cap
            D654 Zener
            Do you have the full schematic that you could share.
            • fubr
              • Nov 2016
              • 9
              P-ON+21V: ~13V
              AMP+13V: ~6.8V
              ALL+3.3V: 3.3V
              There is no chirping when the ribbon to main board is disconnected.
              I suppose I can poke around the main board too. Do I need to disconnect capacitors, or can I just use the continuity tester on my multimeter?
              Yes, page 48 for the schematic, and 66 for the Circuit Board Assembly
              Thanks for the help!
              • fubr
                • Nov 2016
                • 9
                Appalling!
                For my own benefit, can you explain why parallel diodes are worse than a single diode? Is it because there's twice as much chance of failure?
                Or maybe because real parts aren't ideal, and can have different forward voltages, so most of the current will go through the diode with a smaller forward voltage?
                  Have all the connectors/cables in place, no power to the TV and then check the resistance between:
                  GND and ALL+3.3V
                  GND and AMP+13V
                  GND and P-ON+21V
                  • fubr
                    • Nov 2016
                    • 9
                    GND and ALL+3.3V
                    GND and AMP+13V
                    GND and P-ON+21V
                    GND and ALL+3.3V: 621 Ω
                    Gnd and AMP+13V: 1.68 kΩ
                    GND and P-ON+21V: 7.7 Ω
                    So uh, there's the smoking gun I guess?
                    I poked GND and P-ON+21V with cables disconnected and got a value between 20k and 50kΩ (well it said something like 50kΩ at first, and increased, then I probed again after a while, and it was around 20kΩ and increasing)
                    Tested these with a continuity meter too. They don't seem to be shorted , though D654 beeps for a split second? What does that mean?
                    Man, I hope the problem isn't on the main board. It doesn't look very fun to work with, what with so many surface mounts.
                      Well, you have something bad on the main board that you need to trace it to see where that P-ON 21V goes to on the main board.
                      • fubr
                        • Nov 2016
                        • 9
                        Well, I'm in it to win it I guess.
                        I don't think the earlier linked documentation is super helpful since it doesn't even have a model number, and there's just a schematic diagram. That main board is using DDR3 SDRAM, my board has DDR2.
                        Found a picture of the main board BA31T0G0201_3 online, and also have a picture I took of my own board.
                        http://assets.shopjimmy.com/media/ca...ma-001-top.jpg
                        Main difference I can tell between the two is that mine has a heatsink over IC3801
                        I'll keep looking for documentation, hoping to find a matching schematic.
                        Even if I can find a short, it's not really gonna help if I can't tell how to get a replacement.
                        budm, is there any chance you remember what thread it was on that some person found a shorted capacitor on their main board?
                        Edit: Actually I think I found it? https://www.badcaps.net/forum/showpo...&postcount=136
                        Edit2: Oh my god C3214 is actually shorted like citywidetvtech said. Though it looks like C3208 might be shorted too.
                        Now I really need to find the schematic
                        Edit3: Does IACWD mean anything to anybody? It's printed on top of IC3201, and google leads me to an MP1472GJ chip on AliExpress, which matches pg 60 of the documentation linked earlier
                        The Philips 49PFL3708 that the documentation is based on has identical IO to my Element, which leads me to think the main boards are verrry similar, with only a few minor differences like in DDR3/DDR2 ram
                        If that logic jump makes sense, then that means that documentation should work, and I can trust this schematic (on pg60 of the philips service manual):
                        But.. what units am I looking at? 0.1 and 4.7.... ____farads? nano? micro? pico? @_@
                          Just remove one at time the suspect bad caps to see if the low resistance will go away first. They are .1uF and 4.7uF and they are connected in parallel.
                          • fubr
                            • Nov 2016
                            • 9
                            D'oh you're right. Of course. Only one of them needs to be shorted for them all to appear shorted.
                            It was indeed C3214. After that was gone, pins 5 and 7 on IC3201 no longer test as continuous.
                            The resistance between GND and P-ON+21V goes into the 10kΩ range, too.
                            Thank you so much! Hopefully that was the only issue.
                              You can solder in 4.7~10uF 50VDC lytics cap in place for testing purpose.
                              • fubr
                                • Nov 2016
                                • 9
                                Haven't tested it yet, but I did replace the cap with a 4.7uF 35V SMT. This one isn't shorted
                                I was thinking and I realized that the TV only uses a 2 prong plug. Is there any reason why I shouldn't replace that entire wire with a 3 prong plug one, and connect the ground to the chassis of the TV?
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  Current Hogging.
                                  As they warm up, one will take more than the other--which leads to more heating--in that one, and more current flow in that one--while the other passes less current and cools and takes less cools more, so the hotter diode takes even more--gets hotter--till pop!
                                  CRAP design by idiots--Or Accountants--Same thing--Idiots!!
                                  TELEFIX
                                  • the_rem
                                    Unknown transformer : how to find a good replacement part ?
                                    by the_rem
                                    Hello guys,
                                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                    04-23-2025, 01:48 AM
                                  • ttmi100x
                                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                    by ttmi100x
                                    Greetings everyone,
                                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                    Upon closer inspection...
                                    07-31-2024, 06:36 PM
                                  • caseyjay_48
                                    Sony KDL-46BX450 Inverter Troubleshoot Logic
                                    by caseyjay_48
                                    I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                    I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                    09-23-2022, 08:08 PM
                                  • reessi
                                    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                    by reessi
                                    Hello:
                                    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                    I started on the ACER:
                                    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                    10-29-2024, 11:31 AM
                                  • Yanleb
                                    Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                    by Yanleb
                                    Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                    I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                    D608, good
                                    D618 RF101L4S, good (See warning 1 below)
                                    D619 RF101L4S, good (See warning 1 below)
                                    D865 RF101L4S, shorted (See warning 1 below)
                                    IC464 Inverter HA MC74HC1G14, shorted...
                                    03-09-2020, 12:00 AM
