DYP-42W3 BN44-00204A Standby voltage STD5V appears only for a few seconds.
  • jczarniak
    • Oct 2015
    • 179
    Got dead Samsung plasma 42".
    Standby voltage 5V appears only for a few seconds after plugging the TV in to the socket, then slowly goes down to 0V.
    To measure the voltage again I need to leave the TV unplugged for a few minutes.
    Checked mosfets, diodes, cold solder joints , can't find anything.
    Need your help guys.
    Thank you.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: DYP-42W3 BN44-00204A Standby voltage STD5V appears only for a few seconds.
    maybe worth a read and has a schematic and some tests you can do
    https://www.badcaps.net/forum/showth...ht=BN44-00204A
    • jczarniak
      • Oct 2015
      • 179
      Thank you.
      Measured voltage between CB808 capacitors legs.
      Waving between 11.85 - 16.03 V
      Is this normal, please?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        I suspect the ICB801S (STR-A6159) may be at fault although VCC does appear to be on the low side at 16.03V. It would be worth checking all the components around that IC.
        • jczarniak
          • Oct 2015
          • 179
          Thank you.
          CB801 - stable 342V
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            in the other thread i think they replaced some capacitors too maybe worth putting the board back into the set and heating the power supply with a hair dryer for a good few minutes and see if it starts up then as maybe a bad/high esr capacitor issue.
            • jczarniak
              • Oct 2015
              • 179
              Left the TV unplugged for 2 hours, tried to switch ON, works perfectly.
              Switched OFF, not coming back ON same story
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                So you can ignore ICB801S as it's highly unlikely to be intermittent.
                Check CB808 by heating it up with a hair dryer and then see if the set switches on first time.
                • flocko
                  • Nov 2012
                  • 1121
                  • uk
                  I refurbish these boards, and most faulty board sent to me are with this problem. Replacing all the 50v caps on the hot side is the first step for reliability (CB802/5/6/7/9) of the stby voltage and PSon circuits
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    +1 had this myself, also replace any Samwha Wb, Wl and Xc series caps also test all the small ones near the 5vstby Ic for esr. Ive had the smaller Samwha Rd series caps go high esr causing this fault.
                    • jczarniak
                      • Oct 2015
                      • 179
                      Very nice, that makes sens.
                      I'll replace all these caps and let you know.
                      Thanks a lot.
                      • jczarniak
                        • Oct 2015
                        • 179
                        Capacitors CB808, CB805, CB806, CB809, CB807 has been changed.
                        All problems with power supply, standby voltage etc... gone.
                        Everything works as it should.
                        Thank you guys for help.
                        Regards !!!
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          Thanks for the update glad it was a nice easy fix.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            That's good news.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Awesome thank Flocko for beating be too it lol enjoy the Tv
                              • Ubleha
                                • Sep 2012
                                • 5
                                • BiH
                                Thanks for all.
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • x_orange90_x
                                  Samsung UN55KU6300F no standby voltage
                                  by x_orange90_x
                                  I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                                  Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                                  05-21-2025, 09:59 PM
                                • Bad_IC
                                  Philips TV 37pfl5604h/12 no standby voltage
                                  by Bad_IC
                                  I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                                  These are the voltages in some pins of IC fsq510:
                                  Vcc=18v
                                  D=320v
                                  Vstr=154v
                                  Unfortunately, I couldn't find the schematic
                                  What else could I check?
                                  Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                                  Thank you​...
                                  11-08-2024, 01:07 PM
                                • brock-s
                                  Asus GL503GE 3.3 standby voltage low
                                  by brock-s
                                  An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
                                  Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
                                  Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
                                  07-13-2023, 03:43 PM
                                • Bloutix
                                  Ps5 edm-033 bios and southbridge standby voltage
                                  by Bloutix
                                  i need your help for understanding if there is an issue around my bios on edm-033 and around southbridge pin P16 and P17.
                                  I have removed my Southbridge and when I check standby voltage on the bios, I’ve got this value:
                                  • pin 1: 0,16v
                                  • Pin 8: 3,3v
                                  • Pin 7: 3,3v
                                  I think there is an issue between 3,3v line and cs pin, but I don’t know where.
                                  then this are the values on SB P17 and P16: 0,93v, But I have 3,3v on L17.
                                  Thanks for your help....
                                  10-14-2025, 02:03 PM
