Chinese supplied IGBTs
  • flocko
    • Nov 2012
    • 1121
    Re: Chinese supplied IGBTs
    I dont think Utsource will care to much, at best you will have your money refunded. My advice wait for RS/ Mouser/Farnell +Digi-Key to restock from Fairchild
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      If I get my money back then it's ok. I fixed the tv with original parts from 2 "new" SS boards and I ordered the FGD4536 from a different source. Will see what happens.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        I have a parts tester that comes in a kit. It is pretty acurate with most parts. When I got a few different orders of IBGT's that I found out were fake, I tested them and they just read as a capacitor.around 1250pf.
        • vinceroger69
          • Mar 2012
          • 6714
          have you got a link to the parts tester you have been using thanks.
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            This the one I have.
            http://m.ebay.com/itm/M328-DIY-Kit-C...539?nav=SEARCH
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              #26
              Cool , will order that! Does it read the IGBT's? ( Will it tell if they are fakes or not ).
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                #27
                It will read as a capacitor between two of the legs.
                If its good it will say something like n. e. mosfet and give a capatiance and a voltage. I think it is the voltage needed to make it switch. It does NOT come with directions on how to build it, but its not too hard. It looks like they make better ones now.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  #28
                  Got a reply from UT source saying I need to use them. They say they are 100% original ...
                  Mine all measure 2.7 M Ohm , how do yours measure Flocko/Timmy? Mine are all different batch numbers but I can't remove them with alcohol/aceton.
                  I got a feeling they might be ok but I'm afraid to use them haha.
                  • flocko
                    • Nov 2012
                    • 1121
                    #29
                    They also told TW and myself the same thing about the fake 30F131s they supplied. I was told to test them. But the only real test is to load them on a working board and see if they work.I sent a batch to Toshiba for them to look at, but they would not get involved as Utsource are a clearing house for unwanted components, they said it would be to hard to trace were they were supplied from, just use them or send them back for a refund,as I have said before you can only test them for switching , measuring resistance or capacitance of these components is not a way to test it
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      #30
                      Thanks for your reply.
                      Im not going to try it and ask my money back. Cant afford a damaged SC board.
                      • tvtimmy
                        • Mar 2015
                        • 1160
                        • usa
                        #31
                        Here are some readings from my cheap ass transistor tester.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          #32
                          Thanks , I must wait for that meter to come in. It might not always be correct but it will help.
                          I ordered FGD453TM from a company in hongkong , they are not on ebay. They provided pictures of the component and they look the real deal..... will wait and see what comes in. Hope they are ok so i can start repairing again.
                          30F132 instead of 30F132 ....that not a option?
                          • flocko
                            • Nov 2012
                            • 1121
                            #33
                            The tester is thinking it has been presented with a Mosfet not an IGBT this can be seen by the screen showing MOS + G.D.S (gate /drain/ source).being that an IGBT is Mosfet+BJT devise making it a hybrid transistor it is beyond the range of this parts tester.you could build a stand alone IGBT tester, but that again would only test switching (same as using a meter) not under load testing were the fake components let us down.when I have tested any of the fakes they normaly test fine(swithing) as an IGBT should, but will blow under working conditions (load or voltage).
                            • MICROTECHSERVICE
                              • Jun 2016
                              • 36
                              • United Kingdom
                              #34
                              hi all fgd igbt is cheaper to buy from rs and most of the igbt you get are refurbished or remarked there is lot of fakes you need to know the supplier well and pay bit more you get the right bits
                              • flocko
                                • Nov 2012
                                • 1121
                                #35
                                Refurbished ? how do you do that. is that the put the IGBTs in boiling water trick you post about before on here.RS/Mouser/Farnell +Digi-Key are now all showing stock.
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  #36
                                  No no , he means that there are copies out there. Parts that look the same but dont have the same specs ( 30F131/FGD4536 etc ).
                                  I ordered them from HKinventory , got a nice deal. I compared them to the originals and fake ones.
                                  Fake ones --> stamp can be removed with alcohol/aceton.
                                  Originals --> stamp cant be removed.
                                  Mouser does not have them in stock
                                  http://nl.mouser.com/ProductDetail/F...4VPeT1ImXIXL8t
                                  • flocko
                                    • Nov 2012
                                    • 1121
                                    #37
                                    Digi-key were showing FGD4536 as 1798 in stock , RS also showing stock how many do you want,Microtechservice (proman) said they were refurbished , I asked how do you refurbish a faulty IGBT ? TW has shit loads of them,I am sure he would love to know a way to refurbish them, and so would I, All TO-252 (D-PAK) parts will look the same diodes/ mosfets/IGBTs ,you can only go by trade mark /layout of printing and part number, if these are not as the original parts, then the chances are there fake.
