Samsung PN64E7000 Won't Power On
  • TvTime
    • Nov 2016
    Actually a PN64E7000FFXZA TW02.
    I have an intermittent issue. I will loose the standby light and the TV will not turn on. Occasionally it will turn on and I've been able to watch for well over 5 hours.
    When I loose the standby light I get two scenarios.
    1) low voltage only on the PSU (5V, 3V, 15V); no high voltage (VA, VS)
    2) no voltage at all, and none on the StdBy or PS-ON pins.
    I found the link below and what it is telling me is the PSU is suspect. I pulled the board and there are no obvious issues with caps or solder joints.
    I'm not crazy about small surface mount stuff. Thru-hole I can deal with. What are some easy things to check?
    https://www.youtube.com/watch?v=JjrwTZC5nVg
    I wish I would have found this link sooner, arguably the best U tube Samsung video I've found.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung PN64E7000 Won't Power On
    If you are losing the standby voltage I would be tempted to remove the power supply and check all the solder joints really carefully and if you can, go over them.
    Any capacitors starting to bulge on top or their plastic covers starting to split. If so they need to be changed.
    • Espartaco Smith
      TV Samsung UE40MU6405U, not standby (after power failure)
      by Espartaco Smith
      Hello, as I mentioned in the title, I have a Samsung TV at home, model UE40MU6405U, which is about 5 or 6 years old.
      After a power company failure, the TV stopped turning on and even the standby light wouldn't come on. Over a period of about 10 seconds, the electricity kept going off and on repeatedly, and the TV died.
      The power supply is: L40E6_KSM (BN44-00875A)
      The main board: BN41-02568B
      The power supply board seems to be fine. All the voltages are present. If I disconnect it from the main board, I get backlight.
      I've also checked the...
      12-17-2024, 02:16 AM
    • Chris24
      Samsung UN58J5190 - Doesn't Power on and has Standby
      by Chris24
      Hey everyone - I have a Samsung UN58J5190 with these symptoms: Does not power on, has standby light, standby light blinks 5 times after pressing "power on." When plugged in the power supply is making a very faint ticking sound, and this goes away when pressing power on.
      Following instructions from the great team here in recent posts for Samsung with similar symptoms, I did the following tests:
      I tested with mainboard disconnected from power supply - backlights do not come on (symptoms no change/5 red blinks)
      I tested with T-Con disconnected...
      10-12-2021, 12:43 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • nathan425
      Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
      by nathan425
      Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
      Symptoms:
      • - no power
      • - no standby LED
      What I've done so far:
      - confirmed power supply is OK
      -- CN201 #4 showing 5.3V
      -- BD207 showing 5.3V
      -- removing the cable between the main board and the power board turns on the backlight.
      Pushing the power button on results in no change to any of the pins connecting the two boards.
      - function assembly appears to be NO GOOD
      -- there is no voltage showing on any of...
      11-01-2023, 06:34 PM
    • amennone
      Samsung UE50NU7090U , no power , no led standby
      by amennone
      By inserting power, on the diodes DM856...Dm859, there are 9 volts, when you press the power button the voltage is 12 volts, voltage present for a few seconds, then returns to 9 volts
      The power LED remains off, always.
      Reprogrammed Ic 503 = 25Q40 and IC 501 = 25Q80, downloaded from the site
      The situation remained the same​
      https://**************/dump/lcd_pdp_...oogle_vignette...
      11-17-2024, 04:28 PM
