Lg 32pg6000
  • kondor
    • Oct 2016
    • 8
    • england
    Lg 32pg6000
    Just got one of these for £10 for a project I am doing. I am new to TVs in general apart from looking like a genius for replacing obvious bad caps.
    Tries to turn on, front LED goes from red to green, then relay sound and kicks off.
    On the control board there is an LED that lights green, and another one that starts flashing and then, when relay kicks, it goes off.
    Power Board.
    Tested voltages of power board, all seems fine. Caps look good, but looks are not everything. Waiting for a cheap ESR meter to arrive before further investigation. Did test some diodes in circuit though, and while they were around .450 ish, a few of them were reading 1.800 ish in reverse. This I think is because they were in circuit.
    From the ysus on the left there is another board on right side, quite thick wires joining them, I think that is the xsus (correct me if it is the zsus). Disconnected what I think is the xsus from the ysus. Fault remained.
    Reconnected the xsus to the ysus, disconnected the ysus from the psu, fault disappeared.
    Reconnected the ysus to the psu, removed the mainboard (hdmi, scart ect) from the psu, fault disappeared.
    My next move is to remove the ysus board, and probe ground while running dmm across the connectors (it is a single ysus / buffer board).
    Thoughts, tips, for a new to tv repair person appreciated.
    Hopefully, we can get this thing rocking and I can move on to next stage of project. Which is a virtual pinball machine. As such the TV is allowed some niggly faults, as it is for the backglass and will not be watched like a TV, just for decoration. So I may have a go at replacing buffer ICs if I need to just to get something on it / and practise.
  • kondor
    • Oct 2016
    • 8
    • england
    Re: Lg 32pg6000
    Today I placed a 200w load on the PSU, isolated from the ysus, still connected to the mainboard though, and it seemed to hold.
    M5V on the socket to the ysus kept cycling though, between 5v and 0, for about 8 seconds each. Is this normal behaviour?
    With the load off, I disconnected the mainboard from the controller board and reconnected ysus/zsus, it did not trip off with the mainboard - controller board lead out of the circuit and this gave me chance to measure some voltages on the zsus. I measured the socket on the zsus in pairs, and I noticed that too was cycling, between 109v and 0.
    • kondor
      • Oct 2016
      • 8
      • england
      Re: Lg 32pg6000
      VSC is reading low. 114v instead of 135v.
      Does this indicate Y-sus problem or is it more likely to be the power supply?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Re: Lg 32pg6000
        This sounds line a Main Bd issue to me...
        • kondor
          • Oct 2016
          • 8
          • england
          Re: Lg 32pg6000
          Thanks for the reply Andrew. The main board keeps calling my attention too. Saw a control board for really cheap, bought that, didn't fix. Changed a few typical capacitors on the power board, didn't fix it.
          I am going to pull the mainboard, test it, and then store it if i can not get it working until a reasonably priced one comes available. Might try serial cable to see if I can somehow communicate with it, if I can then I will try to inject firmware. Other than that, its on hold.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Re: Lg 32pg6000
            IGBT's short on Y.
            TELEFIX
            • steviewonder
              • Dec 2013
              • 183
              • england
              Re: Lg 32pg6000
              Maybe worth giving the power supply a good warm up with a hairdrier,then power it up..the caps on these are known to be troublesome..
              • Hamie
                • Apr 2014
                • 1383
                Re: Lg 32pg6000
                Originally posted by Alastair E
                IGBT's short on Y.
                +1
                So the tv turns on and stays on if the y-sustain is disconnected?
                Some pretty strange advice on this thread!
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Re: Lg 32pg6000
                  Aye--Thats what I was thinking too. It seems, everyone's got it in for mainboards these days!
                  Twas painfully obvious the fault was with the Y!
                  TELEFIX
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Re: Lg 32pg6000
                    I think the panel is failed not fixable replace the tcon.....
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Re: Lg 32pg6000
                      Nah--You know what it is....?
                      Too much Copper in the mains-cables! You need to change 'em to good ole Steel!
                      TELEFIX
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Re: Lg 32pg6000
                        WRONG ! Do not comment on this post if you are clueless about electronic repair I have over 69 years in the industry. The fault is the freeview ariel not picking up signal.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Re: Lg 32pg6000
                          Ah, See?
                          Ive only got 38 years exp, A lot of that with Valves (Toobs) and the likes of the Pye-Hybrids 691-697 and Philips G6/G8/G11, ITT CVC2, 5, 9, 20-30,, and those absolutely Hideous Thorn 3000-9500 POS sets that all us oldies, --Except me--, just love...
                          Grundig 5010--now There was a set! --Commutating Thyristor line-timebase, Made lesser engineers cry! I wont mention the B&O 2600 and 3400, Those would send most engineers Mad! Valve push-pull line-output, Brilliant--but HOT!
                          Bring back the A56-120X, PL509 and PCL805 and be done with all these modern flat-screen trash!
                          TELEFIX
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Re: Lg 32pg6000
                            Lol I really have 2 years experience but yet I seem to know more than grown fucking usless men when it comes to fixing Tv's sometimes but only with flat screen
                            • steviewonder
                              • Dec 2013
                              • 183
                              • england
                              Re: Lg 32pg6000
                              I say bring back the A66-701 crt-Ahh those awful Grundigs-with the slimline cabinet.Wonderful with those 12R 11w droppers...that used to fry randomly because of the leaky washers underneath those thyristors...Like how Alistair didn't mention the Pye 731..
                              Back on track-I mentioned the possibility of caps on the psu-As the VSC is not as low as would be expected with blown IGBT'S?..possible i suppose...But personally,I would replace the tripler,or the R5010 transistor on the cyclops psu...Wrong fuse in the plug reece?
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Re: Lg 32pg6000
                                No you dont need a fuse in the plug just some tin foil Stevie think of cost saving
                                • kondor
                                  • Oct 2016
                                  • 8
                                  • england
                                  Re: Lg 32pg6000
                                  LOL.
                                  OK, Tomorrow I start to take out the transistors and test them, or buy another t con, or freeview (currently have it connected to ESPN Caribbean downlink, hang on, nah its not that).
                                  I do not personally think it is the PSU, but I will see if I can beg a hair dryer off one of the neighbours. In an insane way I really want to start pulling these transistors and testing them now though.
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    Re: Lg 32pg6000
                                    Why pull 'em out?
                                    I test 'em in circuit. Look for shorted ones, less than 100 odd ohms C-E
                                    --In fact--Its best you Dont just pull 'em out, as doing so risks damage to the part and board, plus mixing them up--They aint all the same types....
                                    TELEFIX
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Re: Lg 32pg6000
                                      Yeah jokes aside test them before removing. Also as the buffer is part of the Ysus youalso need to test them as failed fets can damage the buffer.
                                      • Alastair E
                                        Chief Womble
                                        • Mar 2013
                                        • 1963
                                        • U.K.
                                        Re: Lg 32pg6000
                                        Ah yes--Its a 32" combo board innit!
                                        I had one some years ago, I would replace the IGBT's, it would run for an hour--Then bang again.
                                        Replaced lots, still bang, replaced lots more--bang again, always after some time of normal running.
                                        Never did find just why it self-destructed so frequently, Got bored with it--scrapped it.
                                        TELEFIX
