How to determine if HDCP keys are revoked Samsung UN46D6000SF
+ More Options
Posts
  • AcGeorgiegirl
    • Jun 2013
    • 202
    My tv has had "No Signal" when hdmi cord is attached to any hdmi port, from my cable tv stb. The TV says, "Check signal cable" once I unplugged the hdmi cord from the port. I've made sure the device I'm using can work with other TV's in my house, no problem. This TV will work with hdmi connected from a FireTV stick, though.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: How to determine if HDCP keys are revoked Samsung UN46D6000SF
    Maybe go to the samsung site and try a firmware update if there is one.
    • AcGeorgiegirl
      • Jun 2013
      • 202
      Yeah, thanks, I'd done that, as well as reset to factory.
      • llonen
        • Sep 2014
        • 495
        • hampshire
        How many other hdmi devices have you gotten connected to the cable set top box
        • budwich
          • Jul 2015
          • 3097
          maybe update the settop box (which is what model?).
          • AcGeorgiegirl
            • Jun 2013
            • 202
            I don't have any other hdmi devices currently plugged to the STB. It only has one hdmi out port. In the past, I've successfully connected 2 other tvs to the hdmi.
            The box is a Cisco Explorer 464OHDC2.
            • budwich
              • Jul 2015
              • 3097
              unplug both the stb and tv from power. disconnect the hdmi cable at each device.
              reconnect the hdmi cable. plug in power at the TV, turn it on.... does it see that that the hdmi incoming port is "occupied" by a cable (ie. not greyed) but no signal is received?
              IF so, power up the stb box. does the tv status change?
              Samsung hdmi implementation is not certified so there can be interop issues. Further, lots of stb boxes also have implementation issues... perhaps a replacement box is necessary.
              • AcGeorgiegirl
                • Jun 2013
                • 202
                I had the stb's power still unplugged when I reconnected the cable. The tv said, "Check Cable", and the port wasn't grayed out. Then I plugged the stb in, and the message changed to "No Signal". I've actually had the stb replaced recently for this problem, but it made no difference. I don't have any other device to test the hdmi ports on the tv with, except a laptop. Would that help?
                Last edited by AcGeorgiegirl; 11-09-2016, 11:51 AM. Reason: Left off something important.
                  • 31015
                  test the cable on a different tv.
                  • AcGeorgiegirl
                    • Jun 2013
                    • 202
                    The cable works fine.
                      • 31015
                      if the cable works fine, the box works fine, and the tv works fine.
                      then probably your box is set to output some resolution or frequency that the tv cant handle.
                      i have seen this when connecting European PS3 consoles to monitors - the monitors dont like 50Hz sync.
                      • budwich
                        • Jul 2015
                        • 3097
                        good "observationing". As you can see from your "tests", the tv does detect that indeed the hdmi cable is plugged in, hence the "plug detection" circuitry appears to be fine. Then upon powering up the stb, the "edid" work along with a few other things take place in the hdmi protocol before video happens. The error, "check cable" appears to indicate a physical layer issue as opposed to upper layers / apps (ie. hdcp). As part of the "edid" signalling, the source attempts to "read" the display's capability. Failure to do that would like represent a "lower layer" issue (physical) as there usually isn't much going on as it is a pretty basic "memory read".
                        Since the "firestick" works, it appear to indicate an issue with the stb interoperating with samsung's hdmi implementation... maybe. There are lots of posts thru out the internet with stb issues with samsung (and others). "Fixes" that I have read, usually point to software updating of both display and source, box replacement, cabling, and "wishing"... :-)
                        go back to the other display (the one that works) with the same box and cable.
                        check all the settings in the box including things like "deep color", "color space", "auto", etc. Try turning off anything or setting "auto" to a specific setting. Further try setting speed to 720p.
                        Last question: has this ever worked with this display?
                        Next to last question: what software is the stb running?
                        • AcGeorgiegirl
                          • Jun 2013
                          • 202
                          Thank you for the techie background info for how the hdcp thingy works...very helpful! Your question of whether the stb has worked on this tv before...no. In fact, the guy who I bought the tv from also was using the same cable company's stb, and he sold it because it began not displaying on hdmi ports, as well.
                          I'll go through the settings, as you've suggested, of the stb while connected to my other TV, let you know.
                          • AcGeorgiegirl
                            • Jun 2013
                            • 202
                            The stb settings allowed for just basic video choices, and I took away the 480p & 480i. that left 1080i and 720p. This didn't change anything. I then adjusted the tv's settings as I tried with the stb..nothing changed. I then went into the stb settings, and took off the 1080i, leaving only 720p(while still connected to the TV that has the problem). Nothing changed.
                            • budwich
                              • Jul 2015
                              • 3097
                              what software version is on stb?
                              ensure that you have turned off CEC (anynet) in the tv.
                              how long is the hdmi cable that you are using?
                              • AcGeorgiegirl
                                • Jun 2013
                                • 202
                                I'm working on getting the stb's software version. Anynet was on. I turned it off.
                                • AcGeorgiegirl
                                  • Jun 2013
                                  • 202
                                  The software is "VCS version for CIDTV 2.0.9.004 for 8-bit set tops"
                                  Also, the date was 2010-2011
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    I don't think that is the firmware version for the stb... that's the software version for the caller id "app".
                                    turning anynet off is good BUT it think you might have to go thru some "sequencing" like I suggested earlier (unplugging, powering, etc).
                                    • AcGeorgiegirl
                                      • Jun 2013
                                      • 202
                                      yep, it is the caller id thingy, sorry! I hear ya on changing the AnyNet choice/unplug, etc. I'll try that next.
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        I overlooked your previous comment about the original owner indicating that the tv worked at one time with the "same box" but then stopped. Since it works with a firestick (and probably with the your pc... you can try that too, just confirm), it does appear to point to the stb. from my reads, this stb box appears to have limited support.
                                        A check of the firmware would be wise (haven't seen how to do that thru the documentation... very poor, but expected from stb makers). I suspect that perhaps a software update may have "broken" things perhaps.
                                        Depending on what you have access (even thru friends), you might try wiring in some sort of intermediate hdmi device... receiver, splitter, switch,etc that might act as a "buffer" between stb and tv.
                                        when you indicated that you checked for a tv update, did you actually try a "usb based" update or just a "check for update"? what version is on the TV?
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
