Sharp LC-80LE645E Flashing 2-5 :-(
  • vakuum
    • Oct 2016
    • 24
    • Swiss
    #41
    Re: Sharp LC-80LE645E Flashing 2-5 :-(
    If I disconnect one ribbon cable from T-Con than one side of the TV is complete white and the other side is with this dark picture without green....
    If I disconnect the other ribbon cable it is the same but left and right turned.....
    The voltage of T-Con is 11.9V ....
    I have ordered a spare T-Con now.... we will see.....
    • budwich
      • Jul 2015
      • 3097
      OK... but while you are waiting, I would check as many voltages as labeled at connectors to ensure that they are there... especially ones going to the main board.
      • vakuum
        • Oct 2016
        • 24
        • Swiss
        #43
        TV WORKS!!!
        A new T-Con has fixed the Problem and it works.... now I will mount all togetter and test again.
        So I think the blown small little ceramic cap has damaged the T-CON Board....
        great! :-)
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • dmcabs
          SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
          by dmcabs
          Hey guys,
          I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
          This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
          FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
          I'm a bit rusty but still have ability to dig right down.
          I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
          09-21-2024, 11:09 AM
        • JunkmanJimbo
          sharp lc-65ub30u plays but screen is flashing on and off
          by JunkmanJimbo
          Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
          09-07-2024, 09:45 AM
        • scubacamper
          Sharp Aquos LC-70C6400U Half Screen Dark
          by scubacamper
          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
          05-03-2025, 12:19 PM
        • STKR123
          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
          by STKR123
          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
          I wonder if re-flashing the BIOS might be of any use here.
          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
          11-03-2024, 06:58 AM
