Need Firmware for SHARP LC-32le140e(VESTEL 17MB62-2.5)
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Hello.I got another tv today with firwmare problems.I revived it flashing a firmware.Now I can turn it on,use the service menu etc.But the firmware version that I flashed is not the correct one.1 Firmware had problems with the panel version and all 3 of them had problems with keypad(it didn't work), the volume would go down to 0 and it scroll through the menu.
    I unplugged the cable which connects the keypad to the main board, used my remote control to change the volume and the volume would still go down to 0.Is there any way I can find the correct firmware.
    SHARP LC-32LE140E, MAIN BOARD VESTEL 17MB62-2.5)
    Thanks in advance.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Need Firmware for SHARP LC-32le140e(VESTEL 17MB62-2.5)
    Try the following link:
    https://translate.google.co.uk/trans...ml&prev=search
    • ducky29
      • Dec 2015
      • 369
      • Europe
      Originally posted by dick_barton
      Thank you but thats the firmware that I used.Im still having problem with the volume going down to 0.Do you think this might be a firmware problem?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        I believe it is a firmware problem. Others may confirm.
        • ducky29
          • Dec 2015
          • 369
          • Europe
          Yep thats what I thought too.I even removed the keypad to verify it.
          • ducky29
            • Dec 2015
            • 369
            • Europe
            Solved.Finally found a good source where I bought the firmware.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Thanks Dick, also have you got link to the Fw OP help others cheers.
