LG 42PA4500 Suspected bad main board (double check my logic)
  • hardwareguy
    • Jun 2006
    • 405
    I just want a sanity check here...
    Got this TV that has funny noises from the Y sustain board, no picture and no sound. Other than a dimly lit black background, it's dead. I don't even get a standby light. The optical audio terminal doesn't have a red light either, which I find odd.
    Vs and Va are happy and I have 5.2 and 17V to the mainboard as well.
    If I short the test pattern pads on the panel LVDS interface board and plug the set in, I get some pretty test patterns. Funny noises from Y sustain cease when the patterns are playing, it gives only a very faint hum.
    This does indeed confirm the main signal input/processor board is faulty correct?
  • sordids999
    • May 2013
    • 2149
    • uk
    Re: LG 42PA4500 Suspected bad main board (double check my logic)
    If you get test patterns then it Sounds like a possible main board fault
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Dont think we needed a thread, you've answered your own question plenty of threads like this that prove also. Your mainboard is faulty, likely bga solder issue but if you dont feel confident reflowing replace the board.
      • hardwareguy
        • Jun 2006
        • 405
        Just confirming here. I don't do many PDP sets at all.
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • matyx
          My macbook pro a1708 is under MDM and DEP and i wanted to change the serial number and Main Logic Board number
          by matyx
          i dont know what im doing I have CH341A programmer and SPI programming cable from chipsetpro.com the curent serial number is FVFWQ1CJHV2F and the MLB number i dont know and the motherboard id is 820-00840-A
          Can somebody please help.
          I dont know how to uplode the .bin file
          02-20-2025, 02:26 PM
        • grimacelord
          Need Help Identifying Component For Printer Main Logic Board HP M570DN
          by grimacelord
          Hello. I know that I am asking for help with a printer, but this is specific to the printer's logic board so I figured it would be best suited under the motherboard repair forum - please move if better suited somewhere else.
          I have an HP M570DN printer that has stopped being recognized by USB. This apparently happened after a lightning strike. I pulled the logic board out of the printer and did a visual inspection of the board under a microscope. Board looks ok. Then I started checking random caps looking for a shorted line somewhere. I eventually discover one. I inject 1V into...
          09-21-2021, 09:11 AM
        • JSin21
          Compatibility of main boards between different variations of samsung MU6100
          by JSin21
          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
          I have Samsung Smart TV UA65MU6100WXXY version DA01
          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
          11-27-2023, 04:54 AM
