panasonic
    panasonic
    powers up but all i get is hello then error code PANASONIC DMR-EZ48V FAULT 99U. so replaced all the bad capacitors in the power board, also read up on how to reset the unit by holding the power button in for 10 seconds to reset the system and still coming up with the error code, i have checked all the other diodes and capacitors in both boards and they seem fine. so if anyone has any ideas would be greatly appreciated.....
    Last edited by peter sevenich; 10-22-2016, 06:36 AM. Reason: needed to add panasonic dvd player and video recorder in 1
    Re: panasonic
    Thank god they only made 1 type Panasonic tv so repair is easy!
    No seriously , what kind of tv / soundbar / dvd is this? Is it a plasma tv or lcd or led? Type number?
    Could you also post some pictures from all the boards inside the tv?
    This way we can provide more help and hopefully come with a solution to your problem.
      Re: panasonic
      Originally posted by moreno83 View Post
      thank god they only made 1 type panasonic tv so repair is easy!
      no seriously , what kind of tv / soundbar / dvd is this? Is it a plasma tv or lcd or led? Type number?
      dvr
      I think U99 is a common failure but I never found a fix for one I had. I suspect the DVD drive unit. I'm sure you've tried a google and get plenty to read but I'm not sure of a solution
