Lg50pb690v
  • sparks2112
    • Mar 2016
    • 20
    • uk
    Lg50pb690v
    Hi guys. Any help much appreciated. Got this TV a while back but never had time to look at it right. Done obvious stuff like caps all good.
    Problem is when turn on screen flashes white/grey split second and goes off no pic. TV still on as can use remote to turn on and off. Would like to start over fresh with some help off anyone please. what to go through,try.test etc. Until we can find problem or parts I will need.
    Like I say any help is much appreciated and can't thank you guys enough just for taking the time to help out.
    Bare with me though as proper noob
  • Hamie
    • Apr 2014
    • 1383
    Re: Lg50pb690v
    Got a Green light on control board?
    • sparks2112
      • Mar 2016
      • 20
      • uk
      Re: Lg50pb690v
      Yes bud green for 1 sec goes out then quick flash. Then off for 2 secs repeat.
      • Hamie
        • Apr 2014
        • 1383
        Re: Lg50pb690v
        OK you see the glue on at the bottom of the y-sustain. Usually stuck to the side of the transformer and a 2.2 ohm resistor.
        The glue becomes conductive and causes havoc to this board.
        Scrape as much of it as possible away.
        This might not be your fault, but try this first and see if the picture comes back.
        • sparks2112
          • Mar 2016
          • 20
          • uk
          Re: Lg50pb690v
          Yes seen a bit something on this forum about a capacitor under that glue c205 I think .cleared glue from that and tested cap seems OK. Going to clear all off now and get back to you soon thanks
          • sparks2112
            • Mar 2016
            • 20
            • uk
            Re: Lg50pb690v
            No change still same
            • Hamie
              • Apr 2014
              • 1383
              Re: Lg50pb690v
              OK so you'll need to check the voltages.
              Annoying this TV tends not to show the correct voltages on the z-sus if the y-sustain is faulty.
              For example (from memory) the VZB voltage should be 140v, but if the ysus is faulty it will sit around 70v
              Also run test patterns on control board.
              • sparks2112
                • Mar 2016
                • 20
                • uk
                Re: Lg50pb690v
                Vzb 140.3 i found a dead resistor r563 on ysus changed it .just noticed a small spark when booting up now. ysus a mosfet d442 going to check that out back soon
                • sparks2112
                  • Mar 2016
                  • 20
                  • uk
                  Re: Lg50pb690v
                  My bad lol. Not soldered resistor right. Resolded and now spark gone.va and vs and standby voltages correct.m_on & rl_on read 3.31v when tv turned on. All voltages right going to zsus and ysus. Not sure what I'm looking for to be honest. Need to more research on parts and testing. I'm more a cap or board changer
                  • sparks2112
                    • Mar 2016
                    • 20
                    • uk
                    Re: Lg50pb690v
                    Well getting late work in morning. will look in tomorrow
                    Thanks for help so far
                    • Hamie
                      • Apr 2014
                      • 1383
                      Re: Lg50pb690v
                      So you need to check -vy and vsc voltage on the y-sustain.
                      • sparks2112
                        • Mar 2016
                        • 20
                        • uk
                        Re: Lg50pb690v
                        Hi hamie really sorry on late reply. I work on marquees and can be away for days/weeks at a time.just got back will get back on this tomorrow and let you know. Sorry again sparks
                        • Wutru
                          HP Elitebook 820 G4 BIOS repair assistance required
                          by Wutru
                          Hi guys,
                          If someone would be able to provide some expertise, I'd be very grateful.
                          BIOS Corruption - Cause
                          So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                          After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                          09-06-2025, 10:32 AM
                        • techpointhull
                          NO POST Nightmare - DFI G7L330-B Industrial Motherboard Socket 775
                          by techpointhull
                          Hi Guys,
                          Newbie here to board repair so bare with me. I have a bunch of Socket 775 motherboards from arcade gaming machines. The brand is DFI, and it's their industrial motherboard range model number G7L330-B
                          All boards have the same issue, no POST. I've re-capped the boards completely, can't see any shorts across the 12V rail and I've removed all MOSFETS from the board to test them. The boards have been ultrasonic cleaned as well as an alcohol bath, doesn't seem to have made a difference
                          BIOS is also correct, I do have a working board for reference...
                          11-21-2023, 10:57 AM
                        • MBAS111
                          medion ERAZER Crawler E10 fresh bios
                          by MBAS111
                          Was wondering if anyone could help with a fresh copy of bios for medion erazer crawler E10
                          10-30-2025, 09:14 AM
                        • MrBojangles
                          Z690P WIFI D4 need to split BIOS file
                          by MrBojangles
                          This motherboard has the unfortunate thing where it splits the Bios file into one 16 Mb part and 8 Mb backup and I still don't know how to perform the split.
                          I don't know if the procedure is specific to this board or if there is a general rule on how to do this. I would appreciate if someone could do it for me. Thanks ...
                          08-18-2025, 03:00 AM
                        • roxboy1984
                          Hp 15-P104NI Laptop switches off with new Battery when AC unplugged!! Please help!!
                          by roxboy1984
                          Hi Guys,
                          Please could someone help I have a very strange issue with an HP 15-P104NI, The laptop wont boot unless the charger is connected despite the brand new battery. when I connect the charger with the battery installed the laptop takes forever to initialize the display but it eventually boots and the battery will say 100% however if I remove the charger it shuts off.
                          If i boot the laptop with the battery disconnected, the display initializes quickly and the laptop boots normally.
                          I have tested the battery as well as the charging current to the...
                          10-21-2022, 11:05 AM
