Working backlight and sound, but no picture (55LA6208)
  • Carlozzz
    • Oct 2016
    • 9
    • Zuid holland
    I have a problem with my 55LA6208 LG led tv. When I turn on the tv, I only see a black screen. The black screen is powered by the leds in the background, so the back lightning is working fine.
    The problem is that I don't see any pictures on the screen.
    I think the fault wil be in the mainboard or the T-con board. I already measured the fuse on the T-con board, the fuse is just working fine.
    So I have a tv with sound and a black screen powered by leds.
    Is there anybody who knows what my problem could be?
  • johns1mj
    • May 2015
    • 242
    Re: Working backlight and sound, but no picture (55LA6208)
    Please include pictures of the back of the tv including input and t-con.
    First double check connections. You can try disconnecting one ribbon at a time to see if half a picture shows up.
    • Carlozzz
      • Oct 2016
      • 9
      • Zuid holland
      There are two flat cables on the T-con board going to the screen, i disconnected one ribbon at a time, but it did not change anything, it is still a black screen with led lighting behind it.
      Here are some pictures of the back of the tv:
        "I already measured the fuse on the T-con board, the fuse is just working fine." working fine? Do you mean it shows <1 Ohm of resistance?
        So did you check to find out if you have 12VDC at both ends of the SMD fuse on the T-CON board with ref to the chassis GND?
        • Carlozzz
          • Oct 2016
          • 9
          • Zuid holland
          Yes, there is 12VDC at both ends of the SMD fuse with ref to the chassis GND.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Let's see what we have:
            1. BL-ON working as Backlights are ON
            2. PS-ON working as TV is Powering ON
            3. Audio working as TV sound can be heard
            4. T-CON Bd Supply 12Vdc is good as 12Vdc is seen on both sides of Fuse
            What input are you using?
            Is this happening on ALL inputs?
            OK then try cleaning and re-seating the Flat cable between the Main Bd and the T-CON Bd....Wipe the gold fingers on both ends with Isopropyl alcohol.
            If that doesn't work then your Main Bd needs fixing/replacing
            • Carlozzz
              • Oct 2016
              • 9
              • Zuid holland
              Thanks for the feedback!
              I got this problem on all my inputs, if the problem was only on one input, I would have seen some pictures or input message when I changed channels. I tried cleaning the flat cable between mainboard and T-con board, but it did not make any difference.
              Can I test something else to make sure my problem is in the mainboard and not the T-con board?
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Yes you can check these voltages on the T-CON Bd.
                Measure and report these voltages:
                1. VGH (V0n) 20~30Vdc Gate ON supply
                2. VGL (Voff) -5~-8Vdc Gate OFF Supply
                3. VDD (Vlogic) 1.8~3.3Vdc Supply Logic Input (especially this one)
                4. VDA (AVdd) 13~20Vdc Gamma Supply voltage
                • Carlozzz
                  • Oct 2016
                  • 9
                  • Zuid holland
                  I got these voltages:
                  VGH: 0Vdc
                  VGL: -6.94Vdc
                  VDD: 0.5Vdc
                  And I could not find the VDA
                  I hope you know what the problem is.
                  Thanks in advance!
                  • Hamie
                    • Apr 2014
                    • 1383
                    Well with voltages like that you have a faulty TCON.
                    • Carlozzz
                      • Oct 2016
                      • 9
                      • Zuid holland
                      I changed the t-con board, but there is still no picture on the screen. The voltages I measured are the same as on the old t-con board.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Disconnect the 2 panel cables from the Tcon and measure those voltages again.
                        Fault finding at a distance without the set in front of you is difficult at the best of times and you have had several helpful suggestions hopefully leading to narrowing down the fault.
                        • Carlozzz
                          • Oct 2016
                          • 9
                          • Zuid holland
                          Thanks!
                          Measured it again without the cables connected:
                          VGH: 27,9Vdc
                          VGL: -6.9Vdc
                          VDD: 16.8Vdc
                          • Diah
                            • Feb 2013
                            • 6437
                            did you used before this fault your mobile screen mirroring with your LA6208?
                            in case you did or not, now you have LVDS com signal has being changed., this happen too if some one play with hidden menu EZ_Adjust.
                            try first to reset it to factory state by using (Smart Remote apk )at mobile android such galagxy S5 or any one had IR sender. the function button at this program called ( In_Stop ) one time press then with yours TV RC put 0413 the TV will go to stand by.. leave it one minute then start it again. hope your screen come back
                              Originally posted by Carlozzz
                              Thanks!
                              VGH: 27,9Vdc
                              VGL: -6.9Vdc
                              VDD: 16.8Vdc
                              It sounds like you LCD panel is loading down your VGH supply when you gave the ribbon cables between the T-CON and the LCD panel connected.
                              Example of how VGx are generated and what they are for.
                              https://cdn.badcaps-static.com/pdfs/...b317805c9b.pdf
                              https://cdn.badcaps-static.com/pdfs/...6c316493a3.pdf
                              • Diah
                                • Feb 2013
                                • 6437
                                this is LG IPS Panel. had different feeds as usual. they shared this tech only with Sony. . there are no drops.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  +1 Does appear to be some sort of loading on the Tcon supplies and I would be suspecting a possible panel fault.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Hello Diah,
                                    Can you explain a little more what you think the problem may be regarding IPS panel.
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      Expect the panel itself. LG make utter shit panels!
                                      TELEFIX
                                      • Diah
                                        • Feb 2013
                                        • 6437
                                        Originally posted by dick_barton
                                        Hello Diah,
                                        hello Paul
                                        over years till now, never found IPS Panel from LG get any operation Fault unless faced visibility damage by human.
                                        the method where you use over this forum disconnect T-CON ribbon to Panel wouldn't work , because the feed are absolute different. its mean one half will be white but when you disconnected the other one only both side will be black,
                                        there are no problem with panel.. as i said if it not had damage on right side down when you facing the panel
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • Audeze
                                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                          by Audeze
                                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                          Does...
                                          10-06-2024, 08:54 PM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • maxim2511
                                          LG 55EC930V OLED - swich on swich of no screen
                                          by maxim2511
                                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                          Then I get an idea to take it apart and clean boards from dust.
                                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                          05-14-2021, 02:21 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
