Working backlight and sound, but no picture (55LA6208)
Re: Working backlight and sound, but no picture (55LA6208)
Ive seen dozens of dead LG panels--prob the worst of the bunch the 40" and 42" are notorious--utter turds....
--and--Not damaged or cracked, just dead just like this, no image/nothing on screen with known good t-con, psu and mainTELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
dear Alastair : you were right.. but not IPS panel. check again please.Comment
this is the service manual for this serialAttached FilesComment
So what is the best thing I can do right now? Can I measure something? I really want to know what board is broken and why I don't see any picture.
I already changed the t-con board, so that is not the problem.Comment
We already know that you DO HAVE Backlights per post 1 and post 3 (it is still a black screen with led lighting behind it.), but the VGH goes down to 0V when he ribbon cables between the panel and the T-con board, and when you disconnect the cable the VGH comes back to normal level again, so it is either the TFT drive ICs on the panel shorted out or the caps on the tab bonding board is/are shorted out.
You can check the resistance between GND and the VGH test point to see what you get when you have the ribbon cable in place and not in place. Something is killing the VGH power supply or the VGH power supply is too weak even though you had replaced the T-CON BUT with a GOOD ONE?.Last edited by budm; 11-22-2016, 02:46 PM.Never stop learning
You can check the resistance between GND and the VGH test point to see what you get when you have the ribbon cable in place and not in place. Something is killing the VGH power supply or the VGH power supply is too weak even though you had replaced the T-CON BUT with a GOOD ONE?.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
by AudezeI have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
Does... -
by Daren87Hello everyone,
I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the... -
by maxim2511My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
Then I get an idea to take it apart and clean boards from dust.
In side of Tv was not so bad, I take compressed air in can, and gently blow up.
Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... - Loading...
