LCD TV won't turn on. LED keeps blinking
  • sahan14
    • Oct 2016
    • 52
    • sri lanka
    #61
    Re: LCD TV won't turn on. LED keeps blinking
    red lead for the 12th pin its ok. and black pin for? i didn't get it
    like this?
    • vinceroger69
      • Mar 2012
      • 6714
      #62
      the large capacitor you have been testing 325 v on use the negitive side of that capacitor for your black multimeter test lead,
      • sahan14
        • Oct 2016
        • 52
        • sri lanka
        #63
        0.85v in vcc and the - cap
        board is not connected to the tv. but powered and switched on
        • vinceroger69
          • Mar 2012
          • 6714
          #64
          ok thanks now we need to trace back and see why the voltage is so low bear with us as im still leaning myself so maybe dick or budm can advise what too check next as i cant seem to fnd a schematic/service manual for your set
          • sahan14
            • Oct 2016
            • 52
            • sri lanka
            #65
            is it the problem with IC?
            • sahan14
              • Oct 2016
              • 52
              • sri lanka
              #66
              ok thanks now we need to trace back and see why the voltage ..........schematic/service manual for your set
              thank you vinceroger69
              • vinceroger69
                • Mar 2012
                • 6714
                #67
                with the tv turned off and unplugged what RESITANCE do you get between the vcc pin and ground pins like you marked in your picture .
                • sahan14
                  • Oct 2016
                  • 52
                  • sri lanka
                  #68
                  310 k ohms
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    #69
                    Can you post clear bright pictures of the top and bottom of the power supply board. Take it out into the sunlight and take the photo's. It's difficult to identify anything on the boards.
                    • sahan14
                      • Oct 2016
                      • 52
                      • sri lanka
                      #70
                      image is too large. may i upload as a winrar?
                      • sahan14
                        • Oct 2016
                        • 52
                        • sri lanka
                        #71
                        pictures
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          #72
                          Why is there a piece of wire connected from R9 to G of mosfet?
                          There are quite a few solder joints that do not look very good.
                          I see that some of the mosfets have been taken out. Have they been checked using your ohm meter
                          Have you also tested D8, ZD3, D12, Q4, ZD3 and D4 using your ohm meter?
                          I think it would be best to order a replacement power supply.
                          • sahan14
                            • Oct 2016
                            • 52
                            • sri lanka
                            #73
                            solder joints are now ok. i checked them.
                            i replaced all components .
                            the wire is now not on the board. it soldered by me.
                            i soldered the wire because Q1 is not connected to the GND i thought the path is missing. but the wire did not solve the issue
                            • sahan14
                              • Oct 2016
                              • 52
                              • sri lanka
                              #74
                              i tested ZD3, D12, Q4, ZD3 by removing
                              they are working...
                              also D8 is working
                              • sahan14
                                • Oct 2016
                                • 52
                                • sri lanka
                                #75
                                Thnk you dick_barton for the advice.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #76
                                  IMO seems like the SMP Ic is not running.
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    #77
                                    Unfortunately I don't think sahan14 is familiar with repairing which is why I suggested a board replacement would probably be the best course of action.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #78
                                      I have too agree with you now too i would source a replacement board.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #79
                                        psu schematic
                                        • sahan14
                                          • Oct 2016
                                          • 52
                                          • sri lanka
                                          #80
                                          I can replace the IC. yes.. I don’t have good knowledge with repairing. but i can understand what you are telling..
                                          • mar1in
                                            LG UH652T doesn't turn on and stands is blinking once a second
                                            by mar1in
                                            I've got this LG TV here that wouldn't turn on and be stuck in a standby loop (blinking red once every other second).
                                            Did test the following:
                                            * LED's seem fine as they all light up using LED Tester
                                            * Power Supply supplied around 111V for each LED Strips (2x edge lid strips)
                                            * PWR_ON would be at around 3V but dropping every other second (just like the standby light)
                                            * DRV_ON is doing the same
                                            * power supply has a green LED onboard, but that doesn't seem to do anything (stays off the whole time).
                                            * there is a tiny clicking...
                                            11-10-2024, 06:23 PM
                                          • jxrepman
                                            Asus X453MA won't turn on and green led light blinking
                                            by jxrepman
                                            Hi there,
                                            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                            I have checked the charger and it is giving 19+ V
                                            I have disconnected the battery and pressed power button for 30 seconds.
                                            I tried another RAM stick.
                                            Tried disconnecting the keyboard and touchpad.
                                            Tried disconnecting the HDD and the wifi adapter.
                                            The problem persists.
                                            Hope you could help me out on this one. Thank you.
                                            12-14-2024, 06:40 AM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • my dodge
                                            HP ZBook 17 G3 Mobile Workstation LA-C391p won't turn on and the power light is blinking
                                            by my dodge
                                            Hello
                                            I was looking for a schematic or board view but unfortunately I didn't find anything.
                                            By connecting the drain and source of pq58, the device turns on and works perfectly, but the battery doesn't charge, and I don't know the path of the circuit to the MOSFET.
                                            Is the problem with the adapter? Or is there a problem with the MOSFET activation circuit?
                                            Please guide me.
                                            Thank you.​
                                            12-12-2024, 08:37 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
