new never used 50pm670t - za fault
  • dragonlord6
    • Oct 2016
    • 5
    • england
    hi any one got any idears before starting to swap boards
    re LG 50pm670t - za fault
    the plasma pannel was brand new never used was stored still in box for 3years
    ran for 5 mins perfectly before developing fault
    original asumed it was caused but amp and xbox was hooked up to onkio 818 and a xbox looked away for a min then fault developed
    however other gear is fine no fault and working
    it bee suggested it may be corup firmware
    however i have no idear how to sort firmware with no screen seemed top make sense as screen looks more like a test card that a board problem
    or dose it look like control board or logic board
    pick of fault
    upload png
    https://s22.postimg.org/6hwod7vup/20161011_005017.jpg
    anyone got any idears
  • Hamie
    • Apr 2014
    • 1383
    Re: new never used 50pm670t - za fault
    Run test patterns on control board.
    If patterns are perfect replace mainboard.
    If fault remains replace control board.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Mainboard issue, absolute shit Tvs these are from Lg IMO.
      • dragonlord6
        • Oct 2016
        • 5
        • england
        thanks guys apreiciated
        iv already replaced it with a panasonic 4k 50inch led dint buy a expencive panel for that room original as I use the projector more than panel in that room
        but was looking at useing it for a pc monitor may be worth as it a new panel never use if i can pick a main board up cheap
        just trying to find info on jumpers for test pattens
        • cliff_hootarski
          • Jul 2006
          • 411
          Does your control board look like this one:
          http://www.ebay.com/itm/LG-50-50PM67...QAAOSwmtJXZe4I
          On the control board, look for two through the board pins labelled Ext. Auto. Gen.
          Short those pins together, remove the LVDS cable between the control board and main board, plug the TV in.
          Should start the test patterns.
          • dragonlord6
            • Oct 2016
            • 5
            • england
            just had a thort as it was brand new out box and did run for 3mins im think if it was duff from factory i would have expected it to DOA
            rather than running for 3mins before snuffing it from new
            i wonder if worth pulling the board and take look and run the rework gun over it incase its a bad joint
            • dragonlord6
              • Oct 2016
              • 5
              • england
              not shaw at moment mate its not on bench its a few mouths since i had back and took a look
              think ill get up on bench and check mpn tomorrow and have another look
              really appreciate you input guys seems a wast to chuck a brand new panel away that only run for a few mins
              when it would make a nice monitor
