Panasonic TX-P50G10 Mainboard in TX-P42G10..
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    I had need to fit a mainboard from a 50" FHD Panasonic to a 42" set.
    I had thought I would need to change EEPROMS over, but just tried the board as is with no alterations.
    It worked--but had Mal-Discharge, not terrible, only on bright scenes it was purpling up and noisy.
    Tried Increasing the VSUS from 209 to 215V this only made it Worse, all other voltages seemed normal.
    I reduced VSUS to 200, and this resulted in a perfect picture, even the test-images in test-mode were fine. Another tiny victory!.....
    TELEFIX
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Panasonic TX-P50G10 Mainboard in TX-P42G10..
    Awesomeness
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      The Vsus voltage on a 42inch G10 is 199v! Good job!
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Strange thing is, this 42" G10B set's panel was marked, 209V, it had its original PSU, SUS boards everything except the main was original.
        --I'm guessing some parameter of the sustain-waveform is just slightly different between 42 and 50" versions on this Panasonic FHD, and lowering the VSUS by 9V is compensating...
        For longevity--I added a couple of heatsinks to the two large chips on the replacement mainboard, the Analog-Devices chip gets hot enough to burn your finger--That cant be healthy for it!
        TELEFIX
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Hmm thats strange indeed. My 42inch V10 and G10 both have 199V marked on the sticker.
          Those mainboards get really hot. Great tv's though!
          • Buzztv
            Panasonic TC-P42S60 Plasma,how to check Vsus
            by Buzztv
            This is my first post in attempting to keep my beloved 2013 Panasonic plasma tv going.
            About 6 weeks ago the tv was turned on but then immediately shut off. There was no recent power surge or popping noise or any other symptom.
            I checked all of the obvious things and decided to try a replacement power supply board (PSS in Panasonic lingo).
            I would like to check the Vsus but this is one of the final models and at that point Panasonic did not indicate the Vsus and Vad voltages inside the chassis. It looks like they were discouraging people from making adjustments....
            10-27-2019, 01:24 PM
          • SACR
            Panasonic Plasma TH-P42X28K A-Board @ Mainboard Schematic needed
            by SACR
            I need Schematic A-Board @ Mainboard for Panasonic Plasma TH-P42X28K. Code : TNPH0842. I want to replace 1 MLCC but I don't know values (capacitance & voltage) & codes. Can someone help me? Thank you...
            11-20-2023, 11:53 PM
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here๐Ÿค”?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting ๐Ÿ˜‚.
            11-20-2024, 08:52 PM
          • rui4892
            panasonic TX-47AS650E solarized and mirror image after change mainboard.
            by rui4892
            hello everybody.
            my previous post disappeared, perhaps due to the server transition... but let's move on...
            I bought a similar board on ebay but this one is programmed for the 48FHD panel, my panel is 47FHD... in the service manual I can't find information on how to change it... or what to change... thank you.โ€‹
            11-27-2023, 04:48 AM
          • Mirenia
            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
            by Mirenia
            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
            03-30-2025, 06:47 AM
