samsung bn41-01167b main board
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    samsung tv with main board . tv off and on repeatedly
  • sordids999
    • May 2013
    • 2158
    Re: samsung bn41-01167b main board
    Model number of the tv and pictures please of the boards
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      No research no nothing from you, no help from us.
      • hispeck
        • Aug 2015
        • 258
        • nigeria
        here is the main board , and the the model of the tv . LE32B650
        • Asraf Atb
          by Asraf Atb
          01-27-2025, 05:02 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • Lee M.
          Samsung UN75RU8000FXZA bad main board?
          by Lee M.
          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
          11-08-2023, 07:46 PM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
