Hi everybody i have a completely dead tv here im trying to fix for a friend, i have already tested the fuses that are known for going bad and there fine so im starting to think it is a regulator. This set has no bulging caps and seem to be of high quality nichicon, but yeah this thing has no standby led, dosent power up nothing anybody that would help would be greatly apreciated, also i will post pictures if needed i come from teamx360.co.uk and i know theres nothing that pisses off og members then a newbie not posting pics. all i get is the vizio logo turning orange when power is apllied nothing else
Vizio GV47LFHDTV10A Dead
Re: Vizio GV47LFHDTV10A Dead
Yes, we do need good clear pictures.
'all i get is the vizio logo turning orange when power is apllied nothing else' That means the standby power supply is working otherwise you will not be getting the amber VIZIO.Never stop learning
Output connector of the power uspply board are labeled to tell you what they are, so take the DCV reading and report thEe DCV readingof each pin.
Make sure to report in the format for us to easily see what are there what are missing.
I.E
24V pin = xxxV
'A' pin = xxxV
BTW, I cannot see the label for all the pins, the wires are in the way.Never stop learning
Is this exact match to your board?
Vizio 0500-0507-0260 Power Supply for GV47LFHDTV10A
http://www.shopjimmy.com/vizio-0500-...upply-unit.htmNever stop learning
yes that is the exact match and the only one im getting voltage on is the 2 5vstandby pins which is 5 volts, im thinking one of the voltage regulators is bad but maybe not becasue i cant turn on the tv so i dont know if the psu is giving the motherboard all the voltageLast edited by Super360; 10-02-2016, 10:03 PM.Comment
And nothing else on other pins, especially the PS-ON pin?
If that is the case then you need to test all the Voltages of the Voltage regulator ICs of the main board next.Never stop learning
https://s11.postimg.org/9yluqbchf/IMG_0030.jpg im going to go back at this tommorow will be back thoughLast edited by Super360; 10-02-2016, 10:39 PM.Comment
That fuse for the 12VDC will not have the 12VDC on it until the main board sends out the PS-ON signal to turn on the rest of the power supply.Never stop learning
so let me just start off by thank you and what would you reccmend i do im thinking about taking out the psu and shorting ps_on to 5v stanby then test the voltage on the psu.Comment
http://www.ebay.com/itm/VIZIO-GV47LF...-/160564019996 will this work do you think?Comment
i wonder whats in the kit maybe a voltage regulator or eeprom icLast edited by vinceroger69; 10-03-2016, 02:51 PM.Comment
https://postimg.org/image/yx1hiyyjb/ here ya guys go 136 the one mosfet that dosent have a out voltage it was 1.36 voltsLast edited by Super360; 10-03-2016, 02:29 PM.Comment
Check the resistance between GND and output of U5 to see if it shows <50 Ohms, if not then change U5 first to get the correct Voltage.Never stop learning
by Iain PHi everybody!
I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
I decided to check the voltages coming off the power supply they are as follows:
connector CN201
pin 1 (18vsb1)... -
Assuming...7 Photos -
by catnappedRecently had my bedroom Vizio D40u-D1 apparently die while it wasn't being used. Noticed the power LED flashing, figuring maybe a software upgrade, but attempting to turn it on proved that wasn't the case. When powered on, the power LED will flash a bunch of times after about 2 minutes then turn off again. Definitely is no picture even with a flashlight on the screen. Had the opportunity to open it up over the weekend. Doesn't apper to be anything out of the ordinary visibly inside, nor any odd smells of escaped magic smoke. Readings from the connector in the corner of the power supply board...6 Photos
by fharris1977Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.1 Photo
by fharris1977Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.1 Photo
- Loading...
