Sony kdl-52xbr4 bad panel?
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    I got this for free last night. Not sure if it is a bad panel, tcon or mainboard.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Sony kdl-52xbr4 bad panel?
    I dont see any pictures?
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Here is one with cable input.
      It looks a bit blurry and a little sluggish.
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        Here is a 15sec video. http://sendvid.com/u6kuafdf
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          A little bump.
          • Diah
            • Feb 2013
            • 6382
            to me its T-CON issue or ribbon cable specially if this effect keeps at same place of the picture
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Sammy 52" panel prone to tab failure.
              • Malachi
                • Dec 2015
                • 1077
                • Usa
                Even if it's a Sony and not Samsung?
                • attainteddragon
                  • Apr 2013
                  • 764
                  • australia
                  i know the 46" kdl are notorious for tab failure.
                  i have 5 or 6 laying around, all bad panels.
                  WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    Ok, thanks. I won't even bother taking it apart then.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      So guessing you dont have the Tv then ? Sont use Shitsung panels !
                      • CapLeaker
                        Leaking Member
                        • 8195
                        Yep. Tab bonds failing...
                        • CapLeaker
                          Leaking Member
                          • 8195
                          Shitsung? LOL I heard of Samshit, before...
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            I have the tv, just haven't opened it up. I had a feeling it was tab issues, that's why I didn't bother.
                            So I didn't see the panel was made by Samsung. I thought you just made a mistake in typing it.
                            • CapLeaker
                              Leaking Member
                              • 8195
                              To me it doesn't matter the manufacturer. Those tab bonds do fail, or someone cleaned the screen and the water ran down. I revived an old Sanyo TV like this before. After 2.5 years, another tab bond (on the other side) failed same way. So we gutted it and chucked the rest as the TV was 10 years old with 25000 hrs on it and replaced it with something newer.
                              • mmartell
                                General Questions on the Relationship Between Mainboard, TCON and Panel
                                by mmartell
                                My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                                I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                                And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                                01-06-2024, 01:32 PM
                              • knoxrebel
                                Bad panel or bad mainboard? Visio E601i-A3
                                by knoxrebel
                                Visio E601i-A3
                                Tv powers on and input is able to be selected/used, but the on screen menu closes as soon as it is opened and the there are some periodic "glitches" of the on screen menus in relation to position and size. I have tried all the system resets,but because the menus are not usable, i was unsuccessful. Does this seem like a panel issue? Odd that it only affects the menus and not the main input picture. I have already tried disconnecting front panel buttons assuming one was stuck down causing the input to continually be scanned or similar.
                                https://www.youtube.co...
                                03-01-2025, 12:14 PM
                              • r3vsEngIT
                                Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
                                by r3vsEngIT
                                65x900h with the panel from a 65x930d.
                                900H: model yr 2020, Samsung panel
                                930D: model yr 2016, Innolux panel
                                spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
                                the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
                                07-11-2023, 11:11 AM
                              • stylishconsultant
                                un60j620dafxza - Samsung No Display Problem
                                by stylishconsultant
                                Hi All,
                                Need help.
                                I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                09-04-2024, 03:26 AM
                              • guidodroid
                                Bad Panel in Sony Bravia X850G
                                by guidodroid
                                Hello all,
                                I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
                                It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
                                Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
                                The issue is not as bad as others that I've seen around, but is indeed noticeable...
                                03-19-2022, 12:08 PM
