LG55LN575V bad panel?
  • Azza111111
    • Sep 2016
    • 43
    • England
    I'm new here, found this forum whilst looking for answers to my latest tv trouble shoot and I'm looking for advice/help with a LG led tv.
    I'm hoping it's not the panel at fault but let me know your thoughts?
    When turned on the screen lights up and a band of vertical thick lines appears and the slowly makes its way across the screen from one side to the other.
    Pressing volume up/down on the remote brings up coloured vertical thick lines down the panel in the area in which the volume is usually shown, same thing for channel up/down ect.
    I have no normal picture.
    I have tried reseating all cables and visually checking all boards for bad caps ect.
    I did disconnect each cable in turn on the tcon but learnt nothing from it really.
    I will take some photos later.
    Any help would be much appreciated.
    Thanks Aaron
  • Hamie
    • Apr 2014
    • 1383
    Re: LG55LN575V bad panel?
    I've had some strange problems with the mainboard on this TV before (well the 50lnand the 47ln)
    Try unhooking half the TCON and see if the image is OK on half the screen.
    • Diah
      • Feb 2013
      • 6435
      sadly things from LG, LN & LM series easily water or cleaning liquid run down on the LCD Tab and make S/C at components .. take look there before you go to change any boards.
      • Azza111111
        • Sep 2016
        • 43
        • England
        Thanks Hamie, Diah,
        I will take a look at both of these tomorrow and report back!! Thanks for the tips!
        • Azza111111
          • Sep 2016
          • 43
          • England
          Here are some photos,
          The first one is pressing the volume buttons on the remote, the seccond is when I pressed the channel buttons on the remote.
          The third and forth are what I see creeping across the screen.
          I will do some further tests after work.
          Thanks for the advice so far.
          • Azza111111
            • Sep 2016
            • 43
            • England
            I disconnected the tcon board a ribbon cable at a time and these are my photos. Screen still had no images but was more stable, and oddly I have sound after unplugging and really plugging in various connections.
            • Azza111111
              • Sep 2016
              • 43
              • England
              All looks OK here, no sign of water marks or any corrosion, I'm leaning towards buying another main board..
              • Diah
                • Feb 2013
                • 6435
                if you have other TV at home try to connect this LG with scart to other one and check the picture , will it display on the other one good or bad
                • Azza111111
                  • Sep 2016
                  • 43
                  • England
                  Hi Diah,
                  I just get no signal on the 2nd tv, made sure it was in scart source and then cycled through the sources on the faulty lg and nothing was displayed?
                  • Diah
                    • Feb 2013
                    • 6435
                    in this case no signal at the other TV, go ahead with replacing the MB.
                    • Azza111111
                      • Sep 2016
                      • 43
                      • England
                      Thanks for your help I will track one down, cheers much appreciated!!
                      • Azza111111
                        • Sep 2016
                        • 43
                        • England
                        Fitted another main board and the problem is the same, had another look and press and check of the bonded ribbon cables to the panel and these are all really good and make no difference to the display when pressed. Could the panel still be bad?
                        Is it worth me trying a tcon board?
                        Cheers Aaron
                        • Diah
                          • Feb 2013
                          • 6435
                          scart signal are shared Video / Audio Signal before V. S go to T-CON, and A .S to Amplifier. if yours LG main board ( main IC ) working and give Audio signal then it should with scart connection will be screened to other TV as scart signal receiver
                          yours LG had Full Scart port . it mean it can send and receive Signal from this Port. you need to try again with this new boards.
                          • Diah
                            • Feb 2013
                            • 6435
                            BTW can you post photo to whole Boards on this TV ?
                            also check the T-CON Fuse ( F1 2A/125V ) read the voltage of it from both side by black probe of yours DMM to GND and the red on F1 pins
                            • Azza111111
                              • Sep 2016
                              • 43
                              • England
                              Thanks for your continued support with this, I've checked the tcon fuse and measuring from ground in dc I have 11v on both sides of the fuse.
                              I tried the scart test again but can't get anything to to display on the known good tv (checked it's scart with a ver to be sure that works) am I possibly doing something wrong here?
                              I'm just going to post the board photos ☺
                              • Azza111111
                                • Sep 2016
                                • 43
                                • England
                                Here we go..
                                • Diah
                                  • Feb 2013
                                  • 6435
                                  you need to put RF signal in LG and it should have sound.. then plug the scart to other TV as scart input... it show you the content of the signal.
                                  • CapLeaker
                                    Leaking Member
                                    • 8325
                                    What you should have done is to verify the LVDS signal with an oscilloscope, before you got a new main board. Maybe the Tcon is shot.
                                    • Azza111111
                                      • Sep 2016
                                      • 43
                                      • England
                                      Sorry I've been a twat, I will connect an aerial and check again later. My bad!
                                      • Azza111111
                                        • Sep 2016
                                        • 43
                                        • England
                                        Probably beyond my skill set at the moment plus I haven't got one lol.
                                        Not too worried about the other main board I will just sell it on.
                                        • Anonmis
                                          Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                                          by Anonmis
                                          Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                                          The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                                          12-01-2023, 04:31 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • ridaKHI
                                          Samsung LCD panel a320ap20s4lv0.4. There appears vertical lines where ever there is t
                                          by ridaKHI
                                          I have a problem with my Samsung LCD panel a320ap20s4lv0.4. There appears vertical lines where ever there is text . See my pictures.
                                          this problem only happen with HDMI input, not with VGA
                                          the picture is so good with VGA input
                                          Could this be fixed by cutting some kind of tracks on PCB that drives the LCD panel?
                                          vgh even vgh odd signal from Shift Register
                                          and directly connected to panel?
                                          Thanks for all the help in advance.
                                          panel: a320ap20s4lv0.4
                                          main board: 090-6M1814-06
                                          03-24-2021, 02:48 AM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • gentleman
                                          Toshiba 32HL833G vertical lines, white panel
                                          by gentleman
                                          Hi there,
                                          Got this Toshiba 32HL833G that when it turns on, appear black panel whit vertical lines.
                                          No menu, no image.
                                          By pressing the keys menu, input, p+, etc... it change until get white panel.
                                          Like in the photos.
                                          Is it the panel?
                                          I have already unplugged and connected all the cables to the boards....
                                          07-12-2021, 05:00 PM
