47LV5500UA.AWMYLJR Main Board source
  • bajangerry
    • Sep 2016
    • Cayman Islands
    Hi Guys,
    I am trying to find a source for a main board for my 47LV5500UA.AWMYLJR. Apparently I have to get the exact model board or it will not work and none of the sources I have found online so far have one. The board is the EAX63333405(0) main board. The problem I am having is that it is not giving me the 12v for the TCON board and I have not been able to successfully repair it (limited resources here in Cayman Islands to do repairs )
    Any suggestions welcomed!
    thanks,
    Gerry
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
