Sharp LC-42D64U Error Standby
  • SJX1290
    Sharp 50BL2AE stays on standby
    by SJX1290
    Hi,have Sharp 50BL2AE which is not powering, stays on stand by, White control led is permanently on, signal from remote is coming on board as well from power -mutifunctional button on back side. All power voltages seems to be ok. Backlight checked, working..
    Any ideas?
    12-10-2024, 01:17 AM
  • Tecc1229
    Sharp LC- 58Q620U - Standby Light, No Backlights or Image
    by Tecc1229
    Hello, I have a Sharp LC- 58Q620U 58" LED 4K TV.
    When you initially plug the TV into the 120V outlet, I get the initial standby red LED light. After you press the power button the red LED goes out and no other lights come. There is no backlight flash, nor image on screen. No audio with HDMI source plugged in, nor does my laptop detect another monitor plugged in. T-con board makes a clicking sound with or without LVDS cables hookup or off.
    My first thought was that it had a faulty PSU. Reading voltages, I was getting a swinging voltages from the DC output from the...
    09-17-2021, 10:50 AM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • fharris1977
    Vizio D50u-D1 Dead Set No Standby
    by fharris1977
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
    12-28-2023, 10:25 AM
  • rodel21
    Sharp LC32LE265M no standby mode
    by rodel21
    Sharp LC32LE265M no standby mode press the power botton red light blinks only can somebody help
    06-18-2021, 06:11 AM
