panasonic viera lcd tx55as802b
  • Dave b
    • Sep 2016
    • 15
    hi everyone my television(2 years old) will not switch on, it powers up then just switches off, the power/standby light flashes once every 3-4 seconds I have taken it to a repair shop and have been told that the screen is the problem and it can't be fixed does anyone know if that's right hopefully someone on this site can help.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: panasonic viera lcd tx55as802b
    Absolutely no help to us at all. Firstly how many Led flashes and red or green ? Images lf the set ? Voltages tested ?
    • Dave b
      • Sep 2016
      • 15
      (sorry I'm a new to this)the television is 2 years old and just would not switch on, I tried several times using the power button on the side the led light would flash green the picture would come on for about a second then switch off the led light blinks red once every 3 seconds the television is in a repair shop they phoned me today and just told me it was the screen and it cant be replaced.
      • sordids999
        • May 2013
        • 2155
        Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
        just a tip my friend
        • Dave b
          • Sep 2016
          • 15
          its in the repair shop sordids999,have been searching the internet trying to find out what the blink codes mean and if it is the screen when I found this website.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Lol wasn't intended to be snappy, that repair shop sounds like a load of crap doubt it the screen but not ruling it out you need to get it back and we can help you diagnose it.
            • vinceroger69
              • Mar 2012
              • 6714
              As you say the screen does flash for a second maybe a failed led? maybe the tv repair shop dosnt want to repair it hence saying its the panel. If i was you get the tv back home and take some good pictures of the boards in the set then we can try to offer help.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                I agree with Reece.
                I would not be surprised if they told you this:
                "Tv can't be repaired because the panel failed , but we are willing to buy it from you for $50"
                The panasonic tv is detecting a error. Provide some pictures and buy a cheap multimeter. You can use the paperclip option in advanced mode.
                • Dave b
                  • Sep 2016
                  • 15
                  No worries a bit of banter is healthy,I don't have a clue about electronics so any help is appreciated and I certainly don't want to be conned by a repair company that's only interested in getting the set for parts.
                  • Dave b
                    • Sep 2016
                    • 15
                    I have a cheap multi meter that I used for tracing wires in my shogun but wouldn't know where to start in a television, I got a shock from the back of a television years ago from the bit that's like a suction cup.
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      You need to lay the lcd side of the tv down on a tablecloth so you can easily remove the backcover.
                      With the backcover removed you need to take some clear pictures of the boards so we can see how they are connected.
                      When did the fault occur?
                      • Dave b
                        • Sep 2016
                        • 15
                        it happened Saturday took it into the repair shop Monday they phoned today saying its the screen?? still cant find out what the one blink code means on the LCD tv.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          some tvs dont use blink codes.
                          There are panasonic lcd technical guides online the latest i have saw is 2012 version
                          on some panasonic lcds 1 blink means inverter error but your sets so new so may be a diffrent meaning
                          • Dave b
                            • Sep 2016
                            • 15
                            I thought that Panasonic televisions had them to identify where the problem stems from, can find the blink codes for plasma but not LCD ,for plasma 1 blink means STV 5v sense DG Board I don't know what it means its all a bit confusing.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              Try this and see if it works:
                              LCD Panel Test Mode
                              Purpose:
                              To find the possible failure point where in LCD Panel or Printed Circuit Board when the abnormal picture is displayed.
                              How to Enter:
                              While pressing [VOLUME ( - )] button of the main unit, press [YELLOW] button of the remote control three times.
                              How to Exit:
                              Switch off the power with the [POWER] button on the main unit or the [POWER] button on the remote control.
                              How to confirm:
                              If the abnormal picture is displayed, go into LCD Panel test mode to display the several test patterns.
                              And then, judge by the following method.
                              Still abnormal picture is displayed: The cause must be in LCD Panel.
                              Normal picture is displayed: The cause must be in A board.
                              Remarks:
                              The test pattern is created by the circuit in LCD Panel.
                              In LCD Panel test mode, this test pattern is displayed unaffected by signal processing for RF or input signal.
                              If the normal picture is displayed, LCD Panel must be okay and the cause of failure must be in A board.
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                1 blink for led models is :
                                checkpoint 1) A board ( mainboard with hdmi )
                                checkpoint 2) Powerboard
                                checkpoint 3) Panel
                                • Dave b
                                  • Sep 2016
                                  • 15
                                  HI here is the pictures of the power board from the television does anyone know what parts to check and can you please explain how to do this.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    have you tried whats mentioned in post 15 first?
                                    • Dave b
                                      • Sep 2016
                                      • 15
                                      yeah vinceroger69 the tv will not switch on just shuts down been trying the sequence in post 15 and nothing.
                                      • Moreno83
                                        • Jun 2014
                                        • 2008
                                        • The Netherlands
                                        Sorry my bad. Mixed up the service manuals!
                                        1 blink for this model is "BL SOS"
                                        It doesnt cover the fault in the service manual but i guess it's "backlight on" problem. This will be the LEDS or a problem on the powersupply. My guess it's the LED that have failed.
                                        There is no need to test the LCD test option because the tv wont turn on at all. Its only if you see a abnormal picture.
                                          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 05:30 AM
                                        • Natob82
                                          Micro Momentary Push Switch?
                                          by Natob82
                                          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                          12-21-2022, 05:22 AM
                                        • grimacelord
                                          NEC TurboExpress On/Off Power Switch Replacement Help
                                          by grimacelord
                                          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                          11-09-2023, 09:49 AM
                                        • SluggerB
                                          Help making a switch work the opposite way with a relay
                                          by SluggerB
                                          I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                          I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                          It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                          02-07-2025, 07:57 PM
                                        • Paft
                                          Panasonic Viera TX-P42S21B - 7 Red Flashes
                                          by Paft
                                          My Panasonic Viera TX-P42S21B 42" 1080p HD Plasma developed a fault a few days ago.
                                          It looks like it's going to come on, makes that click sound but then goes off. Doesn't turn on via remote.
                                          So, obviously it's likely one or more of the components/boards. I don’t see any results for my model or a service manual anywhere, but I’ve briefly looked into it with similar models and apparently it is the SC and or SM board(s.)
                                          How accurate are the fault blink codes? I don’t see any glaringly obvious damage on the SC/SM boards but the power supply has some markings....
                                          10-21-2020, 07:58 AM
