Re: Anyone familiar with the Akai LCD3701AD?
Okay, I unhooked all the accessory boards (DVD, digital tuner, etc). I double checked all my cables. I hooked up a video source (HDMI), still nothing.
I couldn't find the board with a jumper cable before, so I highly doubt I'll find one now. Akai's website doesn't appear to be any help (ie, not contact information, no technical support, no firmware, etc).
It was around 21$ to purchase the board. I'm thinking of not returning it and trying to modify it. But what do I do? I'm thinking it's a firmware issue, personally. I don't think it's the jumper cables that go to the DIM / GND / BL_O/N jumper. If it was, I should still get sound and I should still get something on the buttons.
Is there a chance another board is damaged, like the T-CON? The PSU has been checked and appears to be providing proper voltage, although the 24VDC was reading around 22VDC. I don't think this would be the issue though.
Should I purchase the parts to make the cable and try to dump the firmware off the bad board? I suspect it's the actual MT8202AG that's bad on the old board. That's the one that holds the firmware. So, even with a cable to download the firmware and upload the firmware, I highly doubt I'll be able to grab it. I could try swapping MT8202AG chips. They're BGA. But it appears the firmware is actually stored on the chip. I guess there's a chance the chip is just the interface to the firmware and the firmware is stored on another chip....but if it is in fact on the MT8202AG, then replacing the chips probably won't work.
I guess it wouldn't hurt to try and "reseat" the old chip. I've never used my BGA rework station before and I'd hate to try on this old board. But perhaps it's just bad solder joints and removing the chip and reballing it would fix the issue? I mean, assuming there's nothing else wrong with the board. There was a bad cap by the analog TV tuner that I replaced with one I pulled off another board. Brown in colour. It was just to see if that fixed the problem. It didn't. Kinda running out of ideas.
What would you do?
What would you do?
