Toshiba 50L4300U - Horizontal lines and interlacing issues?
  • geshtu
    • Sep 2016
    • 8
    • usa
    The Toshiba 50L4300U turns on and seems to work fine except the screen switches back and forth between two states.
    The first has a persistent horizontal black line then it switches everything below that line switches between some sort of fuzzy interlacing issue.
    https://vimeo.com/182938486
    Is it possible it is the T Con board?
  • mmartell
    • Oct 2013
    • 3189
    Re: Toshiba 50L4300U - Horizontal lines and interlacing issues?
    Panel problem. Not repairable.
    • geshtu
      • Sep 2016
      • 8
      • usa
      Well that sucks. Thanks for your advice!
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Could this be a side tab issue?
        Edit
        Didn't quite see how fuzzy the picture became until viewing again.
        • geshtu
          • Sep 2016
          • 8
          • usa
          what would I check for on the side board? I played around with the ribbon cables to see if it might have been an intermittent connection, but didn't notice any changes
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            At the moment it does look like a panel fault, sorry.
            • geshtu
              • Sep 2016
              • 8
              • usa
              Ahh, OK. I will just scavenge parts then.
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • oxi1158
                Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
                by oxi1158
                My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
                I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
                10-09-2020, 08:37 PM
              • Ihandyrepair
                Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                by Ihandyrepair
                Hi guys
                I just started fixing 4k TV few months ago. so I am still learning a lot
                I got this tv from friend complaint is ghosting or horizontal lines on image.
                never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                then it started to show the ghosting white image.
                I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                it has 3 thin small boards at the bottom of the...
                12-05-2022, 04:18 PM
                09-06-2024, 05:27 AM
              • ggil44
                Sony XBR-65X750D Horizontal lines bottom of screen
                by ggil44
                Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                05-30-2023, 07:51 PM
