Insignia NS-42PDP (LG 42X3) - Green Screen Problem
  • BlackSS
    • Sep 2016
    • 4
    Hey guys I'm having trouble with this old tv I have in my sons room. I've had it since new in 2006. A few years ago the ZSUS board went bad and I replaced it. Even before the screen had the some red and green sparklies here and there. They seemed to mostly go away after the TV was on for awhile. This is not my main concern though.
    Over the past month the screen would randomly get washed out and have a lot of green. When the screen is normally black it would appear totally bright green. It seemed sometimes it would go back to normal and other times we'd have to let it cool down then it might for for a bit again. Now it's staying like this all the time. I've attached pics.
    I checked VS and VA voltage and VSC and -Vy. They were all close. I adjusted them around a bit with no change so I left them at spec. All the capacitors look ok, none are swelled or bulging. Also doesn't matter what input is used.
    Any help would be appriciated, thanks.
  • jimjoe123
    LCD TV Green/Pink screen problem
    by jimjoe123
    I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
    Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
    Then each time...
    02-23-2020, 01:29 AM
  • kokos
    LG 55EG910v (Green Nosie Screen) BURNT on NOT ?
    by kokos
    Hi ! to all fellows out there!
    I have an LG 55inch 55RG910V-ZB Curved TV. With the following problem: When I turn it ON with Remote I get a Green noise Screen (attached foto).
    I have tried reseating all ribons, Checked PSU 24V,12V,3v ,etc voltages.
    The TV opens on the first Green noise screen and it freezes there -no respone of menu keys ,etc -only on/off via Remote. (I also noticed carefully that except from green noise screen there is a ghost image at bottom and left vertical side)
    I tried connected the lan and I can seee TV via local lan (as a device I...
    02-26-2024, 10:48 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • String2016
    samsung np300e green screen
    by String2016
    I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
    07-26-2025, 04:00 AM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
