Re-assembling Element FLX-3211B for testing
  • lkvee
    • Feb 2009
    • 198
    Previous owner went inside the unit and left the cable to the T-Con board disconnected. I wanted to reconnect everything so I can test voltages coming from the power supply board. I am assuming these voltages can only be measured on a fully assembled TV.
    Looks like there's some damage to the port on the T-Con board.
    I tried and tried and tried, but I could not get the connector seated correctly.
    I get the funny feeling previous owner got a replacement T-Con board and found out it won't play nice.
    Was really looking forward to testing since all the specified voltages were printed on the board.
    How can I reconnect this cable?
    Re: Re-assembling Element FLX-3211B for testing
    The female connector on the T-CON is damaged, I do not know what else you can do, it looks the owner did not know how to properly disconnect the cable from the T-CON.
    • R_J
      • 9535
      That metal shield is all bent and in the wrong position, the tabs (red) should be in the white plastic and the shiel (yellow) should be back further, then the plug should connect. You should be able to measure voltages on the power supply and main board even with the lvds cable disconected
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • alltvrepairs
        Lg TCon test pins for screen test
        by alltvrepairs
        i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
        Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
        Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
        Appreciate your help....
        06-13-2025, 06:33 AM
      • angelos
        TCON and self diagnosis!
        by angelos
        Hi Guys.
        I have experienced something rather unique and need to find out by the forum what to make of it.
        I got in this set, a JVC or Telefunken LED TV whose complaint is that sometimes the set comes up blank with the back lights running. So I switched on and yes there was a blank screen and back lights were running. I checked the fuse on the TCON and sometime later I lifted the set off the table to check the image (the TV has no feet to let it stand upright) and noticed the set was cycling red, green blue, test pattern, blank then all over again doing this. Suddenly the no signal...
        09-19-2022, 03:05 AM
