Grunding TV flickering picture
  • 6ot4hr
    • Oct 2014
    • 87
    • Croatia
    Hi guys, I got this Grunding TV set that at first didn't want to turn on only one quick flash of backlight and back to off. Voltages on PSU are okay, +24V, +12V +5V stby etc. LED inverter gives +89V and the LED's work bright.
    Anyhow after disasembling the screen and forcing BL-ON and seeing that LED backlight is okay (no burned leds) TV decided to start working but the picture is flickering when on.
    Anyone had a similar issue, my only thought is that there is a Cap with high ESR or shorted and me starting it kind made some of his life to come back
    Video below:
    https://www.youtube.com/watch?v=fUycJ5keOVM
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8326
    Re: Grunding TV flickering picture
    We need some pictures of your boards, model number of your TV etc.
    When your TV flickers like that, what does BLon do? Try to turn down your backlights and brightness as far as it goes. See if it still flickers.
    Does your TV have an automatic backlight adjust (for when its daylight or night time) turn that off.
    • 6ot4hr
      • Oct 2014
      • 87
      • Croatia
      Okay, left the TV to cool off - naturally it wouldn't turn on at first. After letting it warm up for 5 minutes (it tries turning the backlight but fails after 1 sec) eventually it turned the backlight on but still no picture.
      After heating the Caps on mainboard using hot air gun it started and works great. Backlight on, no screen flicker.
      BL_ON is 2.8V (when the backlight is on), 0V when off.
      Motherboard model: YNG190R-12
      Inverter model: INV32L04
      Some pictures:
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Looks like a Beko chassis, I would suggest checking all the small regulators Ive had a Beko Lcd mainboard where it was stuck in standby which was due to a failed 1.2v reg.
        • 6ot4hr
          • Oct 2014
          • 87
          • Croatia
          Quick update:
          Left the TV on for 5 minutes and it lost picture - but backlight is on.
          Reheated the mainboard and the picture came back, so definitively an error in that area
          Gonna dig some more, maybe replace the caps and reflow the main ic. Cheers!
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8326
            sounds like bad caps to me.
            • 6ot4hr
              • Oct 2014
              • 87
              • Croatia
              Update: Checked all caps, esr is between 0.3 - 0.7, also replaced 3 main ones on mainboard - didn't help.
              Tried reflowing the main IC chip, didn't help. Picture is okay only when the main IC is hot (heated with hot air gun)...
              Looks like defective mainboard chip
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8326
                That sux. Well... I guess you're in for a new main board!
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  Before you order a new main check low voltage regulators around the processor. You may be lucky to have one of those at fault and not the processor.
                  A working TV? How boring!
                  • 6ot4hr
                    • Oct 2014
                    • 87
                    • Croatia
                    Thanks will do that
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • CyberPhoenix
                      Issue with picture quality of Sony bravia TV
                      by CyberPhoenix
                      Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                      01-22-2024, 02:08 AM
