Panasonic tx42-p42x20E problem
  • i0n
    • Sep 2016
    • 12
    • Spain
    Hi
    First for to all for this forum. I have a plasma problema and i think The only solution is change mainboard.
    I only find boards for panasonic tx42-p42x20 B but my modelo is E, from Europe.
    Is ok for my tv?
    I send you photo:
    THANKS AGAIN!
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic tx42-p42x20E problem
    Definitely A board. Looking at the service manual the B version will operate the tv and all the eeproms and flash chips have the same numbers suggesting they're the same. Try it and worst case you may have to transfer some of the eeprom chips over
    • i0n
      • Sep 2016
      • 12
      • Spain
      I dont see TNP Number on my main...
      • tw2005
        • Oct 2011
        • 6458
        What do you see? White sticker or it should be part of the pcb print otherwise take some decent pictures of the board we can zoom in on top and bottom
        • i0n
          • Sep 2016
          • 12
          • Spain
          Board
          https://imgur.com/gallery/KbEcC
          • i0n
            • Sep 2016
            • 12
            • Spain
            Board
            • tw2005
              • Oct 2011
              • 6458
              Right so if the link is to a folder and all the images are of your board then I can make out TNPH0829 and the white sticker has ME TXN/A1LWUE. So that should mean TNPH0829 Rev. ME or part # TXN/A1LWUE.
              Search that and it comes up as used in TX-P42X20B, X20E ,
              So you could search either of those numbers to find one. There must be an option to select your region maybe someone else will know that.
              http://www.shopjimmy.com/panasonic-t...tx-p42x20b.htm
              http://www.tvparcasi.com/U995,102,pa...main-board.htm
              • i0n
                • Sep 2016
                • 12
                • Spain
                Jimmy dont open and tvparcasi dont answer...
                And repair It? What i have to change?
                • tw2005
                  • Oct 2011
                  • 6458
                  Unless you're an electronic specialist with equipment to replace BGA chips I don't like your chances.
                  If the Shopjimmy site is blocked you could try phone or email. They only have one of those boards.
                  Otherwise keep searching or go to ebay where you will find Shopjimmy has it listed anyway.
                  http://www.ebay.es/itm/Panasonic-TXN...oAAOSwZ1BXdpvV
                  Toll Free: (877) 881-6492
                  Work: (952) 881-6492
                  EMAIL
                  sales@shopjimmy.com
                  ADDRESS
                  2300 West Highway 13
                  Burnsville, MN 55337
                  • i0n
                    • Sep 2016
                    • 12
                    • Spain
                    EMAIL
                    sales@shopjimmy.com
                    ADDRESS
                    Thanks so much, but It is fnish in B. My model is from Europe, finish in E, different tuner
                    • tw2005
                      • Oct 2011
                      • 6458
                      yes.
                      So on the barcode sticker does your part number match up with that of the B?
                      I thought it did unless the photos you have that link for are not of your board.
                      • i0n
                        • Sep 2016
                        • 12
                        • Spain
                        yes.
                        Are from my board, but I don't see the number.
                        So in Spain the model of plasma finish on E
                        • tw2005
                          • Oct 2011
                          • 6458
                          I don't understand how you don't see the number, they're your photos and I'm looking at them and I see the number and the same numbers on the "B" version.
                          I see a white sticker in your photo "ME TXN/A1LWUE." and I see the same sticker on the "B" version.
                          Anyway I could be wrong
                          • tw2005
                            • Oct 2011
                            • 6458
                            This is your photo, but maybe you're right being cautious as the manuals don't seem to highlight region selection. I'm purely going on if the part numbers match it should work just changing the region or language is a bit unknown
                            • i0n
                              • Sep 2016
                              • 12
                              • Spain
                              Yes, are The same Numbers, but i think that tuner is different. Because otherwise Panasonic make model E and B?
                              • tw2005
                                • Oct 2011
                                • 6458
                                I'm out of ideas for you then. If you swapped over ever eeprom and the 48pin flash IC from your board to the replacement it would turn into your old board.
                                Ii did this once using a new Zealand board for Australian , TV channels were different frequencies steps. It worked.
                                The tuner module is the same but the channels and frequency steps are determined by whatever data is on the eeprom.
                                • Hombre
                                  • Jul 2013
                                  • 231
                                  • Croatia
                                  It should work.
                                  I had an G10E and motherboard died, then bought B (britain) mainboard and it's working, without any problems.
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    Indeed , it really does not matter. I also repair tv's with a british or german mainboard. Just install the board , factory settings , choose language. In europe it wont even ask for region , only if you use a british mainboard. ( It will ask england or ireland ).
                                    Ps , in the Netherlands they only use HDMI for inputs. Nobody uses the cable anymore...
                                    • i0n
                                      • Sep 2016
                                      • 12
                                      • Spain
                                      Originally posted by Hombre
                                      It should work.
                                      I found a good electronic repair in my city..
                                      Any knows which piece I have to change?
                                      • i0n
                                        • Sep 2016
                                        • 12
                                        • Spain
                                        Upp
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • hugocarmo
                                          Panasonic TX-24A1UN CRT Sound and Input problem.
                                          by hugocarmo
                                          Hi.
                                          I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                                          It is imaculate inside, almost no dust or debris inside.
                                          The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                                          So I started to look for a service manual, I found one, and started from the beginning.
                                          Most of the times the caps are the problem so I orderer all the caps for all boards,...
                                          04-26-2025, 07:45 PM
                                        • renech
                                          panasonic TH-42PC77U plasma television half screen problem
                                          by renech
                                          hello,
                                          I hope someone on this forum can assist me.
                                          I have a panasonic TH-42PC77U plasma television.
                                          the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                          i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                          I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                          I have read some posts that suggest the problem is related to the boards on the left...
                                          12-12-2022, 06:53 PM
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
