LG 50PA5500 No Audio Issue - Partial static video
  • Shorteous
    • Sep 2016
    • 6
    • US
    Back story:
    I have a LG TV initially had no video but had clear audio. Did some trouble shooting and narrowed the issue down to a bad YSUS board and bad upper YBuff Top.
    Further Isolated the top most IC as having a short between input voltage and a few of the "header lines".
    Replaced all three boards: YSUS and Upper/Lower Ybuffers.
    Upon Turning the TV back on, the screen flashes and now there is only a snow like image on the bottom bar. All other bars are black.
    Continued Trouble Shooting:
    Removed the top buffer board, Checked for shorts between V/datalines there was no shorts. Powered on TV with no top buffer and there was no change, only the bottom most bar had any image. (Audio still fine).
    Checked VSC, it was fine at 150V.
    Checked VY, it was fine at 190V
    Checked ZRB, it was fine at 150V
    Control board gives a Long - Short - Long - Short status indication.
    What are the next steps for trouble shooting? It looks as if the YSustain and Buffers are fine and atleast the voltage in the ZSustain looks to be fine. I was worried about a possible tear in the top YBuff ribbon but I did not see any and the board seems to have survived multiple power cycles since replacing them.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: LG 50PA5500 No Audio Issue - Partial static video
    Have you a picture of the screen?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Plus boards.
      • Shorteous
        • Sep 2016
        • 6
        • US
        i'll take pictures tonight and upload them
        • Shorteous
          • Sep 2016
          • 6
          • US
          So on the control board, the IC gets rather hot quickly. It's not burning hot but it's much hotter than I would expect - especially since it is not driving any images currently. None the less, the should just be toggling DIO anyways as it shouldn't be driven anything directly.
          So I'm assuming the control board is also bad, but is there any other components down stream of the control board that could have been affected as well?
          It looks like the YSUS, YBuffs, ZSUS, and ZBuffs are all ok, the power board seems to be fine as well.
          • Shorteous
            • Sep 2016
            • 6
            • US
            Also, the new top buff board is not installed because I removed it to see if the screen image would change (show half an image) and I also wanted to test the IC's to make sure that an IC did not blow again. The board tested fine and the image was changed in anyway. I just need to reinstall it at some point.
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              🛠 Original Issue
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • ugamazing
              by ugamazing
              12-17-2024, 07:05 PM
            • elmark
              HP 15-cw1002ua strange keyboard issue
              by elmark
              HP Pavilion 15-CW1002UA
              S/N 5CD0251CBC
              P/N 7KE54EA
              Hello guys!
              I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
              It powers on OK and has no other issues except the following:
              • CAPS LOCK does not work at all
              • Fn button toggles Flight Mode
              • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
              • (with SHIFT pressed: 't%' and 'y^' respectively)
              I initially thought it was a keyboard malfunction (internal short, etc.),
              but when I press and hold...
              06-27-2025, 01:10 AM
            • Simone Vergani
              Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
              by Simone Vergani
              I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
              To assist with troubleshooting, I'm attaching two power circuit schematics:
              • Power
              03-05-2025, 02:25 PM
            • wizard13
              Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
              by wizard13
              I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
              I have checked the forum and the available documentation but could not find a solution specific to my issue.
              • Brand & Model: Dynabook Satellite Pro C50D-B-100
              • Part Number (P/N): PYU13E-00C00PFR
              • Serial Number (S/N): 22028896H
              • System Configuration (SC): A1PYU13E1127
              • Motherboard Model: IP3_ACN16_MB_V21_20211222A
              • Power Input: DC 19V –
              02-28-2025, 02:43 AM
