VESTEL 17IPS61-3 shorted output diodes
  • John843883
    • Nov 2012
    • 71
    Hi everyone!
    I've got a 22 inch Toshiba TV which is really just a rebaged Vestel and like so many of these things the PSU has got a shorted diode on the 12v rail preventing it from working.
    Now replacing the diode is simple enough but having read this thread https://www.badcaps.net/forum/showthread.php?t=42137 I'm leaning towards fitting a high voltage fast recovery diode instead but my concern is how hot would such a diode get with the increased voltage drop? Should I parallel multiple diodes up like Vestel did?
    The back of the TV reveals a power draw of 50w max which is just over 4.1 amps @ 12v.
    The PSU is a VESTEL 17IPS61-3 and can only accept DO-201 diodes but I can't find any suitable 300v+ 5 amp schottkys in that package which is why I'm considering a regular fast recovery diode instead.
    The 24v rail currently has a single 200v UF5402 installed which I plan to upgrade to the 400v UF5404 in order to cater for the increased reflected voltage spike which the 12v rails underrated schottky used to clamp.
    If anyone has repaired one of this PSU's before I would be interested in knowing what replacement part you fitted and how long the repair has lasted, I know these boards are infamous for being junk but I'm trying to avoid a repeat diode failure in future from selecting an under rated part.
    Thanks!
  • John843883
    • Nov 2012
    • 71
    Re: Vestel shorted output diodes
    Update: Well I got no replies so I went ahead and installed 3x STTH5L06 for the 12v rail in place of the 2x SB5100 and 1x SR5010 trio whilst for the 24 rail I installed a UF5404 instead of the UF5402.
    The SR5010 is the one that originally failed.
    In hindsight I probably could have gotten away with just installing one or two STTH5L06 but I chickened out just in case they get too hot once the TV goes back to its owner, I made sure to bunch them all together to help with thermal balancing issues.
    The TV now works and is now being tested for a few hours.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      Thanks for the update and the list of replacement parts you used, and im glad you managed to fix the tv for the owner.
      • John843883
        • Nov 2012
        • 71
        Thanks. I just can't believe they didn't use diodes rated for the task.
        Granted I couldn't find any appropriately rated Schottkys in the required DO-201 package but Vestel could of at least made PCB provisions for a TO-220 part, I found loads of them online that would have done the job. But that would require heatsinking and Vestal don't want to spend that extra dollar.
          • 31086
          i would replace parallel diodes with a single one in a to220 package.
          example, some ryobi chargers use a parallel pair of MBR5200 (5A 200v)
          i replace them with an mbr40250 (40A 250v)
          that wont fail again!!!
          • John843883
            • Nov 2012
            • 71
            Nice find!
            Hmm well I just tested by spreading the legs of a TO-220 device and compared it to the shorted diode and it could certainly fit into the DO-201 holes at a push, but I don't think it would last in this application as the voltage spikes across the diode when the TV is first turned on reach nearly 300V!
            And would you believe it I just came across this cute little DO-201 heatsink in my parts box after I had already screwed the TV back together.
              • 31086
              where are the spikes originating? is the opto-isolator not reacting fast enough?
              • John843883
                • Nov 2012
                • 71
                Goodness knows but it appears to be the most common cause of failure in these models. This thread has some waveforms showing the extent of the spikes https://www.badcaps.net/forum/showthread.php?t=42137
                  • 31086
                  btw, you probably dont need a heatsink - the original diodes didnt,
                  and if you mount it vertical or upside-down it already has a copper plate.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    yes i remember toms post regarding this issue im sure your replacements will last a lot longer.
                      • 31086
                      it's a very short spike, i wonder if a parallel snubber cap+resistor would squash it?
                      i have seen that done across schotky rectifiers in lite-on built monitors.
                      • John843883
                        • Nov 2012
                        • 71
                        Yeah I guess I went overkill with the diodes, just trying to make sure they don't fail again at some point down the line (the TV is used in a holiday home 200+ miles away). I don't do this as a full time thing though so sparing an extra component here and there isn't too big of a deal. Maybe the extra junction capacitance will reduce the peak voltage lol.
                        With a bit of luck If it wasn't for that thread I would have just fitted some exact replacements and assumed current hogging was the cause.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          You can use a 10amp 200v rated TO220 with a small heatsink thermally glued to it. It will last longer than the Tv will fact. Also if its a 17MB95 I suggest you factory reset it after fixing the diodes as they are shite boards anyway. Heres a IPS that I did the diode mod too also done it to others:
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            The reason for failure is because of the way Vestel run the supplies I wont go into much detail but the diodes are over voltaed at start up, I also read that the way Vestel bend the legs of the diodes can lead to failure as the legs stress the diode but Im unsure if thats the real cause.
                            • John843883
                              • Nov 2012
                              • 71
                              Originally posted by ReeceyBurger123
                              You can use a 10amp 200v rated TO220 with a small heatsink thermally glued to it.:
                              That's a neat way of doing it! But unfortunately I don't have any thermal glue to hand.
                              Also if its a 17MB95 I suggest you factory reset it after fixing the diodes as they are shite boards anyway. :
                              Dam I forgot to check, when sort of things usually go wrong? Also are the power LED's supposed to flash a few times during power on? I figure its just the board booting but don't have anything to compare it to.
                              This model is branded as a Toshiba 22d1333b so maybe its a custom thing they have going.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Thermal silicon is cheap off ebay, about £1.50 for a 10 gram tube and it works well tbh. Also theres alot of issues with the software corrupting causing the standby Led just to flash, its normal for it to flash at startup though. Luckily for you if the firmware does go I have a thread which has the firmware for that exact Tv for free so your fine
                                  • 31086
                                  10g??
                                  you got robbed!
                                  http://www.ebay.co.uk/itm/131516987160
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Lol thats probably just melted plastic in that though
                                    • John843883
                                      • Nov 2012
                                      • 71
                                      Is this stuff suitable for future repairs? http://www.ebay.co.uk/itm/Halnziye-H...-/262588989842
                                      Phew, that's a relief. I was thinking maybe the voltage spike which killed one of the original diodes had also taken out something on the logic board so perhaps the flashing was some kind of error code.
                                      Thanks fam, its great that we have people like you out there uploading this sort of thing for the repair community.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Vince you remember the mod I did on that IPS11 with the output diodes thats working great as well ?
                                        • Askic
                                          TVS diode shorted on HP motherboard
                                          by Askic
                                          Hello guys,
                                          I have seen a few videos on youtube about repiring HP 15 pavilion laptops that has TVS (Transient Voltage Suppressor) diode shorted to the ground.
                                          Please have a look at the attached picture.
                                          The diode is P4SMAJ20A and according to the datasheet its breakdown voltage (at 1 mA is 22.2V or 24.6V at10 mA).
                                          THis means that if voltage goes higher that 23V this diode will start conducting and short to ground thus protecting rest of the circuits from overvoltage.
                                          What I don't understand if is this diode reversible, for example if voltage goes below 20...
                                          12-30-2020, 11:56 AM
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                        • Donny2derby
                                          Help identifying shorted diode.
                                          by Donny2derby
                                          Hi there all.
                                          Troubleshooting an SMPS and I’ve found a SMD diode shorted in both directions. The trouble is it has no identification on it. So what do I replace it with and how do I tell where the anode and cathode is and how to mount the replacement?
                                          It is diode D1 on the image.
                                          Regards.
                                          Gareth....
                                          03-07-2024, 08:10 PM
                                        • madyoyo
                                          Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
                                          by madyoyo
                                          Hi
                                          I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
                                          Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
                                          12-01-2023, 09:28 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
