VESTEL 17IPS61-3 shorted output diodes
    • 31196
    Re: Vestel shorted output diodes
    so it needs a recap - what a surprise
    • John843883
      • Nov 2012
      • 71
      Probably then, is it usual for some capacitors these days to go bad without bulging or leaking? The "elite" branded capacitors in there all looked ok visually but they were glued down hard so I didn't ESR test them.
        Re: VESTEL 17IPS61-3 shorted output diodes
        The fault actually has nothing to do with the opto/feedback...you're talking about pulses in microseconds here, so optos won't react that quickly. It's just fundamental to any type of flyback converter, there's nothing wrong with flybacks for power supplies up to around the 50 watt mark they are perfectly fine (if not a tad noisy and inefficient compared to forward or LLC converters, but not a big deal)
        The main issue is because they have tiny primary caps the transformer is wound to work at low mains voltage, it would probably work just fine from 110V AC with some flickering on the backlight.
        The buzzing is normal, nothing you can do about it, probably due to the backlight PWM which is at 100Hz.
        • Rictec
          • Nov 2016
          • 4
          • Portugal
          #44
          i have one of those vestel 17IPS61-3 power boards
          odd is the conector to the logic board as only 12 pins and i cant find where the standby power is..
          fact is i do have a blinking red light and nothing else anyone saw one like this?
          • vinceroger69
            • Mar 2012
            • 6714
            #45
            This looks like a toshiba set i worked on a while ago i had same blinking standy light it turned out too be a eeprom fault what make is the tv and what lcd panel is used in it
            • Rictec
              • Nov 2016
              • 4
              • Portugal
              #46
              its a lousy Branded Electronia but everything inside is Vestel that file you posted there is what i got but i dont have any standby light only 12v on 12 pin of the connector to the logic board
              there is any way i can put the files inside the flash without removing them?
              the tv tries to read the usb pen cos it lights up but i dont think i have a firmware to put there
              anyone have those files the file talks about so i can try them
              thank you
              • vinceroger69
                • Mar 2012
                • 6714
                #47
                try heating or freezing the eeprom and see if the sets now starts up, i couldnt find the firmware for my set so got a replacement mainboard from ebay
                • kevnaff
                  • United Kingdom
                  #48
                  I've carried out a replacement of the 3 SR5010 diodes on the Toshiba 22d1333b. However I now have a TV that flickers over the picture.
                  Any ideas as to what could be causing this?
                  I'm going to try load the firmware on again later and see if this helps
                  • John843883
                    • Nov 2012
                    • 71
                    Back light flickering or the actual picture? What's the ripple like on the main 12v and 24v rails?
                    • shepp
                      • Mar 2012
                      • 377
                      • England
                      #50
                      i would replace parallel diodes with a single one in a to220 package.
                      example, some ryobi chargers use a parallel pair of MBR5200 (5A 200v)
                      i replace them with an mbr40250 (40A 250v)
                      that wont fail again!!!
                      Ive had to swop 2 x MBR5200 in the last 2 month so tried to swop for 2 x P600J diodes but it just cycles on & off so that didnt work.
                      Anyone know if there is a version with wire legs equivalent for the MBR40250? unless I bend the pins to fit but not sure thats a good idea
                      or anyone know of any more other than the MBR40250 as suitable replacements?
                      • guybrushthreepwood
                        • Dec 2013
                        • 44
                        • Italy
                        #51
                        Hello to everyone! I'm working on a Telefunken L22F185D3D. Inside everything is made by Vestel, including this PSU. The television is dead with the only sign of life being the flashing red led.
                        I was confident it had to do with the 'famous' diodes but unfortunately this isn't the case. All the diodes in blue are fine (I've desoldered all of them from the board and tested them off circuit by a multimeter like it might be done if I've correctly understood). I've also tested the coils in red (fine too) and the fuse in yellow (fine, not that I expected anything different: should it have been shot, the TV had been completely dead, no blinking leds whatsoever apart from the fact that usually a bad fuse means a problem elsewhere, am I right?).
                        I've taken the photo online just to underline the components I'm talking about: should someone need a photo taken to my PSU itself, I'm free to make one.
                        I've visually checked all the caps: all of them seem absolutely fine, no bulged ones or else. My knowledge ends here unfortunately... I was used to some pins from where I could get peculiar voltages to check if the output given by the PSU was fine or not but this doesn't seem to be the case or, better said, it certainly is but it isn't so well documented on the board itself like it happens with other boards...
                        What I'm supposed to check now? Maybe the smaller diodes? Maybe the PSU is actually fine and the culprit is the motherboard (I fear this one)?
                        Thanks in advance to everyone for their advices and have a good day!
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #52
                          if you look at the schematic in post 45 what voltages do you get on the connector cn2
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            #53
                            It's always best to have the original board top and bottom pictured. Sometimes people spot faults on the board.
                            Can you give the voltage on the pins of the black connector and the pin name.
                              • Dec 2013
                              • 44
                              • Italy
                              #54
                              Hi and first of all thanks for your prompt and kind replies! Right now I haven't still fitted the diodes back on the board so I can't take any voltage measurement but I'll do it ASAP, I hope in a couple of days or so.
                              What I would do even sooner is taking an actual photo of my board, both sides: Dick's advice is absolutely correct.
                              I thank you both for the advice about the schematic and giving me also a detail image from it. I apologize for not thinking about it by myself and I apologize again because I'm sure I'm going to make a super-dumb question.
                              If I read that schematic well (probably not or at least not completely), from that connector I could take the measurements for:
                              • 12V between 13/14 and 2
                              • 5V between 9 and 2
                              • 24V between 15 and 2
                              Am I completely wrong or am I missing something? I miss 3.3V for example... Please forgive me: I've told you this was going to be a super-dumb question!
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #55
                                you can use the metal tv chassis as a ground then just use the red probe to test the voltages test pins 3/5/7/9/13/14/15
                                i think these sets suffer from eeprom issues so like you say maybe a main board issue
                                  • Dec 2013
                                  • 44
                                  • Italy
                                  #56
                                  @vinceroger69
                                  Yes, I've read about the eeprom issues and I fear it is my case too. Should it be, then I'm lost because I don't think a recovery procedure made through USB by an end-user does exist. Apart from a procedure which may exist, a faulty eeprom remains that and it needs to be replaced before so I'm lost anyway.
                                  I thank you for your confirmation on how to take the measures. Just to learn, given that pin 2 goes to ground, was using it correct too? I assume yes but certainly touching the chassis is handier and this probably is the reason for your advice. Thanks for everything!
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #57
                                    yes you can use any ground on that connector i just find it easier myself to clip black probe onto metal tv chassis we all test things in different ways though.sometimes you can get lucky and heat or freeze the eeprom if this then gets the set powered on you can sometimes read the eeprom data save it then write it back too a new ic
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #58
                                      What about the voltage between pins 3 to 2, pins 5 and 2, pins 7 and 2
                                      • John843883
                                        • Nov 2012
                                        • 71
                                        A shot in the dark here but are all the screws that hold the boards down tight? As I've seen some youtube videos where the chassis is used as a return path between board sections and the heating and cooling cycles and movement flexing can cause these screws to become loose which causes bad connections.
                                          • Dec 2013
                                          • 44
                                          • Italy
                                          #60
                                          Hello to everyone and first of all please excuse me for not coming back before.
                                          First of all, here are the actual photos for my PSU:
                                          the third one being a detail of a thermistor with a black mark on it: it doesn't seem a burning sign though, just some kind of glue.
                                          The readings are very strange, here they are:
                                          3 -0.02V
                                          5 0.00V
                                          7 0.06V
                                          9 0.00V
                                          11/13/14 11.18V
                                          15 0.00V
                                          I know that according to the schematics for the board I'm supposed not to be getting any voltage reading on pin 11 but I've double checked. Also, pin 11 isn't NC as in the schematics but connected to a resistor.
                                          Another difference is that pin 14 and 18 are bridged.
                                          For what concernes the screws, yes I had noticed they were somewhat loose.
                                          • Dvsr
                                            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                            by Dvsr
                                            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                            After replacing the caps I started testing out the speaker. It seemed...
                                            09-10-2025, 10:20 AM
                                          • Askic
                                            TVS diode shorted on HP motherboard
                                            by Askic
                                            Hello guys,
                                            I have seen a few videos on youtube about repiring HP 15 pavilion laptops that has TVS (Transient Voltage Suppressor) diode shorted to the ground.
                                            Please have a look at the attached picture.
                                            The diode is P4SMAJ20A and according to the datasheet its breakdown voltage (at 1 mA is 22.2V or 24.6V at10 mA).
                                            THis means that if voltage goes higher that 23V this diode will start conducting and short to ground thus protecting rest of the circuits from overvoltage.
                                            What I don't understand if is this diode reversible, for example if voltage goes below 20...
                                            12-30-2020, 11:56 AM
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                          • Donny2derby
                                            Help identifying shorted diode.
                                            by Donny2derby
                                            Hi there all.
                                            Troubleshooting an SMPS and I’ve found a SMD diode shorted in both directions. The trouble is it has no identification on it. So what do I replace it with and how do I tell where the anode and cathode is and how to mount the replacement?
                                            It is diode D1 on the image.
                                            Regards.
                                            Gareth....
                                            03-07-2024, 08:10 PM
                                          • madyoyo
                                            Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
                                            by madyoyo
                                            Hi
                                            I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
                                            Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
                                            12-01-2023, 09:28 AM
