VESTEL 17IPS61-3 shorted output diodes
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Vestel shorted output diodes
    Originally posted by John843883
    Is this stuff suitable for future repairs? http://www.ebay.co.uk/itm/Halnziye-H...-/262588989842
    Phew, that's a relief. I was thinking maybe the voltage spike which killed one of the original diodes had also taken out something on the logic board so perhaps the flashing was some kind of error code.
    Thanks fam, its great that we have people like you out there uploading this sort of thing for the repair community.
    Thats the stuff I use yes its fine, also yeah the flashing Led will stop after it boots up glad to help
    • John843883
      • Nov 2012
      • 71
      If I'm ever in Telford again I'll be sure to drop by your shop if I can find it. Last time I was in town I got my head stuck between some railings in wonderland.
        Originally posted by stj
        where are the spikes originating? is the opto-isolator not reacting fast enough?
        Spikes originate from the flyback converter, this is how they all work. When the primary transistor turns off the leakage inductance on the primary causes a voltage spike. This is mostly absorbed by the RCD clamp (resistor+capacitor in parallel with series diode) but only to around 800V or so, usually just a touch below the rating of the primary transistor. This pulse gets multiplied by the ratio of the transformer meaning you can see 100V+ pulses on the secondary. This is also in addition to any secondary-side leakage inductance.
        In the Vestel case the secondary transformer is poorly designed and so 300V spikes are seen. The diode ratings are inadequate leading to failure. Most flybacks typically only expose the diodes to 2-3x the nominal output, I suspect these power supplies are designed to operate with a lot of ripple on the primary side (100V+, probably, small caps) and so the transformer is designed like this.
        Long and short -> cheap shitty design, easily rectified with a couple pence more, but hey, it's VESTEL. That wouldn't be right!
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Awesome however I dont own a shop, Im 17 and work from home atm but glad to help Also lol even I wasn't able to do anything like that at wonderland, town has changed loads since though nothing like it was sadly
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Long time no see Tom, doesnt matter anyway most Tvs nower days fail in under 2 years even if Vestel did correct that theres another issue just around the corner with them.
              • 31087
              Lol thats probably just melted plastic in that though
              nope, same as the tiny tubes - i'v got some here is use on some set-top boxes.
              • John843883
                • Nov 2012
                • 71
                This is great information! I wonder why it only happens at startup, maybe the feedback loop is just not stable under certain load conditions. Do the voltage spikes happen every time the TV is powered up from standby or just when its been unplugged from the mains?
                Impressive for such a young age, I think you'll go far.
                And yeah most of the larger towns in Shropshire are changing so rapidly, won't be long before they become cities.
                • John843883
                  • Nov 2012
                  • 71
                  it's a very short spike, i wonder if a parallel snubber cap+resistor would squash it?
                  i have seen that done across schotky rectifiers in lite-on built monitors.
                  Apologies but I hadn't seen your post until now.
                  There was already an SMD 1nF + 20 ohm snubber across the diode so theoretically with a bit of tweaking the voltage spike could be reduced to something more sensible, however given the magnitude of the spikes a modified snubber would probably dissipate a decent amount of power under normal operation when the diode see's around 80v.
                  I suppose a transorb would be ideal in this situation, it could even be mounted in an unpopulated diode placeholder. I've got a few of them in stock and wish I'd tried one now
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Cheers also yeah it wont be long before its a city around 20 years or so.
                      • 31087
                      the country does not have that long.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        Probably not
                        • John843883
                          • Nov 2012
                          • 71
                          Just noticed something, is it normal for these sets to emit a low frequency buzz when in use and no video is playing? As I just powered it up now but with no signal being fed to it and the buzzing sounds like its coming from the power supply but could be from the speakers.
                            • 31087
                            loose windings on transformers or inductors will do that - if it has a headfone socket you can eliminate the speakers.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              Yeah its normaly the little led driver tarfo is the cause normally, use some cable ties to pull the mag back together normally stops it.
                              • John843883
                                • Nov 2012
                                • 71
                                Thanks for the suggestion, I can confirm that the buzzing is still there with headphones connected.
                                Hi Reece, Is this the inducter that you are referring to inside the red box? Also have you noticed this low frequency buzzing sound too when servicing these vestel boards?
                                It goes away once the TV is in standby mode.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #36
                                  It could also be the main transformer. Get your ear close and listen to which one is causing it.
                                  • John843883
                                    • Nov 2012
                                    • 71
                                    Its difficult to pinpoint, all I'm really concerned about is if it was doing it before I replaced the diodes and if its normal on these models.
                                    Edit: Couple points of interest is the 12v rail is @ 11.3v whilst the 24v is @ 25.2v, I have a scope available but no isolation transformer so probing anything on the primary side is out of bounds.
                                      • 31087
                                      prod them with a bic pen barrel or something,
                                      if you hit the source the sound will change
                                      • John843883
                                        • Nov 2012
                                        • 71
                                        I poked all of the inductive components with a plastic card and honestly it sounds like its coming from the speakers but everything is so densely packed together that its hard to tell for sure. I'm very hesitant to disconnect the speakers as there are forum posts about this model popping its audio amp and I can imagine disconnecting them causing unwanted self oscillation.
                                        Should it be safe to scope the speaker terminals for AC hum? As I don't have an isolation transformer and I noticed there is a 4.7 mega ohm resistor connecting LV ground to the HV 0v reference.
                                        Edit: There is most certainly hum coming from the speakers.
                                        • John843883
                                          • Nov 2012
                                          • 71
                                          I went ahead and scoped the secondary side since I figured some AV equipment out there is earth referenced.
                                          The 24v rail had some mains frequency ripple around 200mV pk-pk whilst the 12v rail was around 100mV, earlier tom66 mentioned that these things might have undersized filter caps on the primary side so maybe this is normal here.
                                          Onto the high frequency component. The 12v rail is pretty bad at around 1v pk-pk even after the LC filter, before the filter its a messy 3-4v of ringing! I compared the junction capacitance of the new diodes to the old ones and it appears the new ones have a much lower junction capacitance so perhaps that's causing higher amplitude peaks if there is less to be charged up and take some of the edge off from the energy stored in the parasitic inductance of the layout.
                                          The 24v rail looked much cleaner with the usual switching induced blip of around 600mV IIRC.
                                          Unfortunately the owner turned up at this point so I had to quickly reassemble the TV. I guess I'll soon find out soon if the buzzing was present prior to the diode incident.
                                          • Askic
                                            TVS diode shorted on HP motherboard
                                            by Askic
                                            Hello guys,
                                            I have seen a few videos on youtube about repiring HP 15 pavilion laptops that has TVS (Transient Voltage Suppressor) diode shorted to the ground.
                                            Please have a look at the attached picture.
                                            The diode is P4SMAJ20A and according to the datasheet its breakdown voltage (at 1 mA is 22.2V or 24.6V at10 mA).
                                            THis means that if voltage goes higher that 23V this diode will start conducting and short to ground thus protecting rest of the circuits from overvoltage.
                                            What I don't understand if is this diode reversible, for example if voltage goes below 20...
                                            12-30-2020, 11:56 AM
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                          • Donny2derby
                                            Help identifying shorted diode.
                                            by Donny2derby
                                            Hi there all.
                                            Troubleshooting an SMPS and I’ve found a SMD diode shorted in both directions. The trouble is it has no identification on it. So what do I replace it with and how do I tell where the anode and cathode is and how to mount the replacement?
                                            It is diode D1 on the image.
                                            Regards.
                                            Gareth....
                                            03-07-2024, 08:10 PM
                                          • madyoyo
                                            Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
                                            by madyoyo
                                            Hi
                                            I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
                                            Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
                                            12-01-2023, 09:28 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
