Hitachi LE65K6R9 has menu image but no backlights
  • brucetv
    • May 2015
    • 281
    • united states
    I did the flashlight test and when I press menu I can see the menu image but the backlights are not coming on. The power supply voltages look good at:
    5VSB 5.155DCV
    STB 4.544DCV
    GND
    GND
    +5V 5.154DCV
    GND
    GND
    12V 12.20DCV
    12V 12.20DCV
    What is the proper way to check this type of power supply for proper voltages for the led's? It's a power supply/inverter type and I noticed on CON2 it says GND ADJ BK with only ADJ and BK wired. Is that for checking Backlight voltages? Also CON4 has a GND V+. Should there be a voltage there in standby and startup? And it has 4 separate + - for I guess possibly 4 arrays to the backlights on CN 234 and 6. I have a Fluke 115 so do I use the negative probe on - and the positive probe on the + on each of the 4 to check to see what voltage it shows on each of the 4 to see if one has a super high or super low voltage compared to the other's to determine a possible short on one of the led's? And where on earth is the best place for Hitachi parts in the USA? It's not even a year old....what a shame I'm not the original owner and have a warranty. Thanks for the help forum.
    Re: Hitachi LE65K6R9 has menu image but no backlights
    ADJ is the dimming command signal from the main board.
    BK is the same as BL-ON, Backlights On, command signal from the main board, >2.5V = ON for the typical Voltage level, <1V = OFF.
    So what DCV do you have on those pins?
    We also need good clear straight shot pictures of the bottom side of the power supply/LED driver board to see how the backlights LEDs strings are connected together.
    • brucetv
      • May 2015
      • 281
      • united states
      Thanks for the info BUDM
      with the ground on chassis I get
      ADJ 5.020
      BK 4.734
        ADJ 5.020
        BK 4.734
        So you do have correct Voltages.
        • brucetv
          • May 2015
          • 281
          • united states
          Here are some additional closeup pics
            Second request.
            I need good clear straight shot pictures of the bottom side of the board to be able to trace out the circuits.
            • brucetv
              • May 2015
              • 281
              • united states
              It seems all my voltages at the power supply are good and I get the same voltages at the main board connector so I know my cables are good but I'm wondering if there is a shorted led causing the backlights to come on. Can I put the negative and positive leads on those CON 2, 3,4, and 6 where those red and white wires go through the panel to the backlights and check to see if I have consistent voltages? Seems like I read somewhere in the forum that if you see one a lot lower or higher it can indicate a shorted led.
                OK, so I am not going to see the pictures of the bottom side of the board after two requests to be able to tell how the LED strings are being driven and how they are connected together.
                Sorry, I am moving on other thread,
                • brucetv
                  • May 2015
                  • 281
                  • united states
                  Sorry it's a little late but I had to charge the batteries back up in the camera. Here is the pics of the underside of the Power Supply.
                  • brucetv
                    • May 2015
                    • 281
                    • united states
                    Here is another closer pic of the led strip connections underneath.
                      TV is off, then leave the black probe on point 'E' and then put red probe on point 'A' and then turn on the TV to see how high the Voltage goes up to.
                      Turn TV off then move the red probe to point 'B', turn TV on and take the reading.
                      Do the same for point 'C', point 'D'.
                      • brucetv
                        • May 2015
                        • 281
                        • united states
                        ok...I'll have those readings for you shortly. Thanks for the help.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          EEe gads--What crap are Hitachi rebadging Now! (Beginning of the end for Hitachi in 1983 when they started rebadging Salora crud and carried on with Vestel turds today...
                          Looks like those cheapo Chinese cruddy things popular in smaller sizes sold here from supermarkets by oddball makes like UMC! All Utter Trash!...
                          Prolly a few LED's gone short and one (or two) gone open...
                          TELEFIX
                            Yep, HITACHI in name only. Will not be surprised if it has bad LEDs.
                            • brucetv
                              • May 2015
                              • 281
                              • united states
                              A is 0.74DCV
                              B is 0.00DCV
                              C is 0.78DCV
                              D is 0.00DCV
                                A is 0.74DCV
                                B is 0.00DCV
                                C is 0.78DCV
                                D is 0.00DCV
                                Well, that means the LED power supply is not working at all, more in-depth troubleshooting will be required which means you have to trace out the circuits on the board.
                                  BTW, are you getting about 380~400VDC measured between the two legs of the main filter cap when the TV is on?
                                  • brucetv
                                    • May 2015
                                    • 281
                                    • united states
                                    As soon as I took the back panel off the first thing that came to my mind was that this chassis looks familiar so it's definitely rebranded. HKC(Shen Zhen) panel and HKC power supply and AUO Main with a no name huge tcon. Made in China. The main looks similar to Hisense Mains. So, in this case possible shorts on 2 out of 4 strips? By the way, thanks BudM for taking the time to show me how to test the led's on this model. It was manufactured 11/15 and we are starting to see a lot of LG LN Series coming in with bad led's, just a shame to see such a quick failure rate.
                                      You can disconnect all the LED connectors to see if you get the DCV on 'A' and 'C'. I had a couple of HISEN TVs that the LED wire assemblies were shorted (nicks in the wires) to the the chassis inside the panel.
                                      • brucetv
                                        • May 2015
                                        • 281
                                        • united states
                                        Wow, only 161DCV, maybe there is hope. Bad power supply then?
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • alltvrepairs
                                          Backlights required for Blaupunkt 50UN265 (HK50D08-ZC56AG-01) - cannot find a source
                                          by alltvrepairs
                                          I am unable to locate a set of LEDs for this model. Maybe you know a better source: 4 Strips of 8 Leds per strip.
                                          Tried with model or HK50D08-ZC56AG-01 but no luck so far.
                                          Regards
                                          07-06-2025, 08:29 AM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • signal.quest
                                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                          by signal.quest
                                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                          03-17-2024, 10:14 AM
                                        • dicky96
                                          HP Elitebook Screen blank - backlights but no image
                                          by dicky96
                                          Hi guys
                                          I'm trying to fix this laptop screen
                                          Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                          OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                          I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                          04-28-2021, 07:30 AM
