Samsung LN40E550 Dim Screen
  • browserjoe
    • Aug 2016
    • 22
    Re: Samsung LN40E550 Dim Screen
    DP805 measured 0.117 in both directions. Does it need to be removed from circuit and retested?
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      yes remove or lift one side from the pcb and retest.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8342
        If something tests weird in circuit, always take it out or lift a leg and retest it again.
        • browserjoe
          • Aug 2016
          • 22
          Ok, might be awhile until I post back, think my soldering iron is broken, may have to get a new one.
          Thank you for the help so far.
          • browserjoe
            • Aug 2016
            • 22
            DP805 tested .455 forward and OL reverse.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8342
              It should be good.
                Can you check the resistance between the two pads of which the diode legs were soldered to when the diode is not connected?
                • browserjoe
                  • Aug 2016
                  • 22
                  314 ohms
                  • browserjoe
                    • Aug 2016
                    • 22
                    Should I check DP804, QP801S, QP802S or RP821 next?
                    The only problem I see with removing QP801S or QP802S to test would be the giant glob of white adhesive on them.
                      Check DP804, CP811.
                      • browserjoe
                        • Aug 2016
                        • 22
                        Originally posted by budm
                        Check DP804, CP811.
                        DP804 .343 forward, OL reverse
                        CP811 I'm having trouble testing, capacitance test seems all over the place. What is a good way to test these small ceramic capacitors?
                        • chrismurphy
                          • May 2014
                          • 251
                          • australia
                          #32
                          had a similar issue with 40 inch Samsung , turned out to be a faulty main board causing the backlights to go dim as you described , to fix i just cut the PWM control wire from the main board to the power board .....all fixed ,but the backlight is at full power and cant adjust but all good (saves replacing the board)
                            If DP804 is removed, do you read 314 Ohms on the pads of the diode DP805 that you removed earlier?
                            "CP811 I'm having trouble testing, capacitance test seems all over the place. What is a good way to test these small ceramic capacitors?" We are looking for that leakage resistance of 314 Ohms.
                              Right now he is getting only 164VDC on the main cap, the PFC Voltage booster is not working.
                              • browserjoe
                                • Aug 2016
                                • 22
                                Pads for DP805 read 8.9 Mohms and it keeps rising slowly, CP811 is removed as well, should I put it back for this test?
                                CP811 reads 352 Ohms
                                  Great, you found the problem, C8811 has leakage resistance, it should show as open circuit.
                                  Can you tell what is printed on the body of the cap? It is high Voltage cap.
                                  • browserjoe
                                    • Aug 2016
                                    • 22
                                    LB 221k 1kv
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #38
                                      That capacitor seems a common failure as just been reading this thread
                                      https://www.badcaps.net/forum/showthread.php?t=32636
                                        220pF 1000V.
                                        http://www.digikey.com/product-detai...974-ND/4457538
                                        I will go with 2KV one:
                                        http://www.digikey.com/product-detai...022-ND/4457650
                                        • browserjoe
                                          • Aug 2016
                                          • 22
                                          So when I removed the diode and tested resistance across the pads, was the 314 ohms a sign that there may be a bad capacitor?
                                          And when I removed the capacitor and rested the pads and saw the high and climbing resistance (sign of a good capacitor?), was that the next capacitor in the circuit that was causing that?
                                          Then testing the resistance of the capacitor after it was out and seeing it was close to the same ohms as when it was in circuit verified that is the problem?
                                          Please feel free to tell me if I'm completely wrong , I'm just trying to understand some of this.
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
                                          • JunkmanJimbo
                                            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                            by JunkmanJimbo
                                            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                            Please help. Thanks in advance!
                                            08-12-2025, 11:45 AM
                                          • Kiberge
                                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                                            by Kiberge
                                            HI guys!
                                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                            04-22-2024, 11:28 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
