Sharp LC-26AD5E Always On once connected
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello guys,
    Got here a Sharp LCD with this wierd sympton, once i connect the power plug, the tv turns ON (green led on front, and the relay on psu clicks), but the display stays black and impossible to turn OFF with remote or manually.
    I have disconnected a connector (photo above) that goes from psu to the input pcb and now it doesn't turn on once connected.
    Can anyone help me please ?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sharp LC-26AD5E Always On once connected
    Disconnect the other cable lower down and see if the backlights come on when you power on.
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      Even if the led is Green, there no reaction at all of the tv, and the only way to turn it OFF is by removing the power cable.
      Is this problem psu related or is the scaler/input pcb the culprit ?
      If you are talking about the connector lower the one i disconnect, there is no change.
      thanks
      • vinceroger69
        • Mar 2012
        • 6714
        Maybe a eeprom/spi flash chip issue whats the mainboard number?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          What dc voltages do you have or not have at the connectors going to the main board?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Download the manual from
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              1817F4140289 (Photo below)
              I can't download the file.
              • CapLeaker
                Leaking Member
                • 8327
                sure you can... on the bottom of the page... you have to wait a little while,
                This file is downloadable free of charge: ...processing...
                this will turn to
                This file is downloadable free of charge: Get Manual
                • vinceroger69
                  • Mar 2012
                  • 6714
                  main boards are cheap if that is the issue test the psu voltages first though
                  http://www.ebay.co.uk/sch/i.html?_fr...+111b&_sacat=0
                  • passete
                    Living=Sharing
                    • Jun 2015
                    • 487
                    • France
                    On CP3801 Connector i'm missing the 12 Volts on Pin 8 and 9, the rest is OK.
                    Instead of 12V i'm Getting 1,59V
                    this will turn to
                    You are Right buddy, thanks
                    • passete
                      Living=Sharing
                      • Jun 2015
                      • 487
                      • France
                      From the schematic, the Regulator for the 12V is the Q422, it's 3 Leg Transistor, the reference is KTB1151.
                      And indeed on the bottom side of the pcb, on this ic location the epoxy is a little burned.
                      The 100 bucks question, where to find this KTB1151
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        maybe something is pulling the 12 volts down? i wonder if you can jump the psu with resistors too test the psu outputs
                        • passete
                          Living=Sharing
                          • Jun 2015
                          • 487
                          • France
                          Or maybe i should measure with the connector disconnected from the main board ?
                          No, it won't work, cause the psu will not turn on .... shutt
                          • passete
                            Living=Sharing
                            • Jun 2015
                            • 487
                            • France
                            The 12V Lines are linked with many reg's on the mainboard, this is gonna be a pain in the mikta ...
                            • passete
                              Living=Sharing
                              • Jun 2015
                              • 487
                              • France
                              I have replaced Q422 and non Change, i still have 1,58V instead of 12V.
                              I also removed IC3801 and Q3802 but still no change.
                              Can anyone give a tip ?
                                I would check the resistance between GND and PIN 8/9 first, then take the reading between GND and output of the Regulator IC3801, Q3804/3805, 3202 output side.
                                Q3802: do you mean Q3202?
                                Report the readings.
                                BTW, what DCV do you have at the BASE of Q422 and GND?
                                  BTW, if something is loading down that Regulator circuit that bad I would expect the fuse F404 1.6A to blow first.
                                  • survivalbloke
                                    Acer Predator Helios 300 - will not power up if battery is CONNECTED
                                    by survivalbloke
                                    This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                                    06-25-2025, 12:20 PM
                                  • beogeek
                                    820-2915-A Wont power on with battery connected
                                    by beogeek
                                    Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
                                    I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
                                    After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
                                    So to cut the long story short I've replaced U7000,...
                                    02-26-2022, 01:29 AM
                                  • muhuruu
                                    PS5 too many USB devices connected
                                    by muhuruu
                                    Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
                                    05-19-2025, 07:14 AM
                                  • sefoster
                                    Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                    by sefoster
                                    I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                    11-20-2022, 09:29 AM
                                  • gavenb
                                    Sharp LC-80LE661U 80 inch
                                    by gavenb
                                    Hi folks!
                                    I have a LC-80LE661U that had some interesting issues.
                                    Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                                    I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                                    11-12-2023, 02:05 PM
