Lcd TV flickering. Any ideas ?
  • Danvagos
    • Aug 2016
    • 76
    I used this form about a week or two ago to repair in olevia 65 inch TV and it's been great but today after work I turned it on and the top of the screen was slightly flickering and stopped in like a minute or two. Is this somthing to worry about ? Is it the fluorescent tubes ? I did put a main board in witch was not the problem then a t-com board witch was not the problem it was two of the transformer boards. Now I did have a problem with the screen after I change the T COM board it was all different colors I guess I didn't have a ribbon cable in all the way but after sum playing I got that fixed. I did check the power output of both power supplies and the power was all where it should be and within specs. The TV through all of its life has had a very expensive monster power surge protector on it. And no caps looked to be bad even in the slightest. Please let me know what you think also the tv is 8 years old I don't know if that makes a difference.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Lcd TV flickering. Any ideas ?
    Model number please ? Pictures of the boards in the set ? Is the backlight flickering or the Lcd if the backlight is it will be visable through the back of the set ?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      If the model is 265T or similar I remember these do have issues with the inverter transformers failing causing backlight issues.
      • Danvagos
        • Aug 2016
        • 76
        Yes 265fhd when One of the Transformers let go of the TV would go straight to black after two seconds. I believe I have fixed that problem because we have been watching the TV for over a week and we have not had a problem just noticed the top of the screen flickering a little bit today. Goes away within a minute. Is it a sign of a dad tube inside the TV or do I still possibly have another transformer problem ? How long does the tubes usually last and when they die they just completely shut off.
        • Danvagos
          • Aug 2016
          • 76
          This seems to be a totally different problem before it would just shut down.
          • Danvagos
            • Aug 2016
            • 76
            Also I only had the tv on for like 5 minutes then I just let it cool down and turned it back on ad it dose not flicker don't know it that helps
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Well we need to know if its the backlight or Lcd first.
              • Danvagos
                • Aug 2016
                • 76
                How do I tell
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  When the Tv is on can you see the backlight through the back chassis ? Helps if your in a dark room as well. If not then try switching the Tv to a full black screen which as its Lcd will be illuminated blue by the backlight, switch the lights off in the room and see if the flickering area is going totally black or staying backlit but the flickering is on the Lcd.
                  • Danvagos
                    • Aug 2016
                    • 76
                    It was not like a fluorescent light trying to come on I would consider that a on off type flicker this was not a on off flicker
                    • Danvagos
                      • Aug 2016
                      • 76
                      Like I said I just had it off for 10 15 and now it did not do it
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Sounds like the Lcd then, I cant help further until you check it out.
                        • Danvagos
                          • Aug 2016
                          • 76
                          Ok I will try to check it. What if it dose not flicker all the time how can I test it
                          • Danvagos
                            • Aug 2016
                            • 76
                            Ok I tryed it with the contrast in the brightness all the way down and all I see is the light coming from the back light no flickering
                            • Danvagos
                              • Aug 2016
                              • 76
                              So I just turned the tv on this morning and nothing it came right on with no flickering. I don't get it
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8148
                                Don't worry about it. Sometimes TV's and monitors will flicker a little bit in a corner and disappear after a few seconds. That is acceptable on CCFL's. Don't forget, CCFLs age and they probably have quite a few hours on them too. I have a monitor that flickers a bit on the bottom corner when turned on for 3 seconds. So far The monitor is 9 years old and never missed a beat.
                                That Olevia is getting up in age too. I don't think it owes you much anymore. Keep her running until she quits.
                                • Danvagos
                                  • Aug 2016
                                  • 76
                                  I talked with my aunt that on the TV before me and according to her the TV may have been on for 4 to 5 hours a day even if you say the TV was on for seven hours today at eight years that's only 20,000 hours. the TV from what I read should last around 60 or 70,000 hours is that correct
                                    CCFL is rated at 50K hour, you can see that in the LCD panel spec sheet, but in the real world they do not. Worn out lamp will have blackened ends and will start drawing more current, just like your home CFL. Lytics cap does not last that long either.
                                    • reessi
                                      ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                      by reessi
                                      The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                      They are black on the right and gradually fade to nothing on the far left.
                                      They start either after 5 mins or up to 2 hours after so annoying for testing.
                                      They flicker continuously very fast! With a slight pause milli-second every second.
                                      Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                      I tested each half by removing the first the left flex from...
                                      06-03-2025, 09:58 AM
                                    • DrvLikHell
                                      Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                                      by DrvLikHell
                                      Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                                      The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                                      07-05-2024, 02:54 AM
                                    • Jaysean
                                      Acer VN7-591G-70RT Display Flickering
                                      by Jaysean
                                      Hello Badcaps coummunity hope you all are having a bless day,
                                      Hope I didn't post it wrong kinda new at forum site rules and tradition
                                      So I'm dealing with screen flickering problem on my laptop.
                                      I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
                                      so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
                                      [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
                                      [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
                                      10-27-2023, 10:22 AM
                                    • arctor
                                      LG 55uh661v flickering images and lines
                                      by arctor
                                      Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
                                      06-16-2025, 11:57 AM
                                    • Adenitz
                                      Cutting the jumper on Samsung TV to solve the flickering
                                      by Adenitz
                                      Hello to all,
                                      I have just seen this YT video about solving flickering issue on SAMSUNG TV. Reading many comments it seems this works.
                                      But I wonder what is done here and how this solved the issue. I'm not able to find the schematics so cannot explain to myself.
                                      Few years ago I had a flickering problem on one monitor in some factory which I managed to solve by inserting UPS between monitor and power outlet. I also notice on this occasion the flickering was gone if I put insulation tape on the power plug like shown in the attached picture to remove connection with the PE conductor...
                                      01-06-2024, 12:20 PM
