Hitachi 40HXC06U problems
    Re: Hitachi 40HXC06U problems
    So he replaced the IC and the resistor but not the MOSFET, more likely then that his new IC is now damaged too due to the shorted out original MOSFET.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Probably.
      • StephenU
        • Dec 2013
        • 230
        • United Kingdom
        Originally posted by budm
        BTW, MOSFET Q204 is fine not shorted between Source and Drain?
        C205 is the one that blew?
        Originally posted by ReeceyBurger123
        Probably.
        Here goes :
        Replaced damaged IC201 (Original part) and R272 (0.47 wirewound sourced from ebay 3W but 1W as stated in the schematics) ~ ~ BudM will this 3W / 1W difference be ok ?? ~ ~
        Power on BOOOM F100 toast.
        Went straight to the mosfet Q204 thats was toast and gone, complete short.(Yeh yeh I know school boy error. my bad..AArrrggg )
        also took out D104-D107 all shorted
        So now ordered:
        F100 fuses - (in hand)
        Q204 Mosfet (On order)
        D104-D107 (On order)
        IC201 looks visually fine but will try a reverse diode to ground check on all pins. or might just order a new one to be on the safe side.
        Anything else I should check guys.
        Let me know what you think, and thanks for the help.
        Stephen
        • vinceroger69
          • Mar 2012
          • 6714
          I would also replace the SG6742HR ic201 just too be on the safe side.
          • StephenU
            • Dec 2013
            • 230
            • United Kingdom
            I'm trying to source an alternative to the one Mosfet Q204 fitted, the markings on the one that came out the board are MDF4N60 (Datasheet > http://www.datasheet-pdf.com/PDF/MDF...gnaChip-898610)
            original on schematic says FQPFN50C (http://uk.rs-online.com/web/c/semico...50464E35304326) But this is discontinued.
            Stephen
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              sorry ignore the link i found is disscountinued too
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                This is the nearest i can find too the original specs
                http://uk.rs-online.com/web/p/mosfet...33393438383526
                • StephenU
                  • Dec 2013
                  • 230
                  • United Kingdom
                  #28
                  went for it, thanks.
                  Stephen
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #29
                    I have a rs account so went on live chat and thats what they recomended as a replacement so if wrong we will can blame them.
                      BTW, that IC201, if the internal drive output is shorted to GND then the POWER MOSFET will not be damaged, the circuit just will not be working, but if the internal drive is shorted to the VCC (when the shorted MOSFET dumped the 300 something Volt into the Gate drive pin of the IC) which will make the output to be HIGH with steady Voltage at the output instead of high speed switching then the POWER MOSFET will blow, so I would change the IC and check all the Gate drive R/D network for damages.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        +1 check the 1uf 50v MLCC next to the controller this causes this which blows shit up ! Also if the fet fails it blows the bridge diodes too.
                        • StephenU
                          • Dec 2013
                          • 230
                          • United Kingdom
                          #32
                          UPDATE:
                          All new parts fitted >
                          F100 fuses
                          Q204 Mosfet
                          D104-D107
                          IC201
                          All seems good with the psu now but still no standby light activity, I suspect the mainboard is the issue as I had an old one (different version) and tried that and and have standby light activity, it tries to come on but, nothing, i'm sure this part is out of an old set that had corrupt flash, thats whats giving me the indication of mainbaord, i have a few of these mainboards that are faulty are they anyway of fixing them like reflashing etc or just good for parts.
                          Thanks in advance to all.
                          Stephen
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #33
                            whats the original mainboard part number?
                            • StephenU
                              • Dec 2013
                              • 230
                              • United Kingdom
                              #34
                              17MB82 - 1a
                              23110916
                              Thanks.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #35
                                yes i thought it might be as just been reading a few threads which reece has posted in time too look for a replacement main board i guess now.
                                not sure if your board has failed complety as no led light on the tv reece has a video on a update for them but thats with a flashing led yours does not have this.
                                https://www.youtube.com/watch?v=kPCisa9BYkk
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #36
                                  Update ?
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #37
                                    Hi vincerogers69
                                    cpc.co.uk
                                    http://uk.farnell.com
                                    are also good UK suppliers who are happy to take your money if you don't already use them.
                                    • Jaime Morillo
                                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                      by Jaime Morillo
                                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                      The TV was stuck on the logo and I couldn't access the update menu.
                                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                      The image result was good, but the image is inverted.
                                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                      08-18-2025, 11:38 AM
                                    • jean luc ferre
                                      laptop hp g72 b52sf screen problems
                                      by jean luc ferre
                                      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                      i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                      06-07-2025, 03:27 PM
                                    • Hondaman
                                      USB problems?
                                      by Hondaman
                                      Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                      (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                      I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                      08-12-2024, 03:26 PM
                                    • wolf1976
                                      hitachi 50hk5600 problem with display
                                      by wolf1976
                                      hi
                                      i have the above tv and the display starts distorts the display at only in applications like you tube
                                      after and on the didital channels
                                      now without connect the antenna only the image of itsselfs tv i have the image i have in attach
                                      i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
                                      can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
                                      09-13-2025, 02:26 PM
                                    • massimomax
                                      Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                      by massimomax
                                      Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                      spero che qualcuno può averlo per riprogrammare eprom. grazie
                                      Post in English !!!
                                      I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                      02-28-2025, 07:27 AM
