Lg 60pv250
  • im45us
    • Aug 2016
    • usa
    Lg 60pv250
    My son has an LG 60PV250 . The house recently had a lighting strike. Took out his stereo and cable box. The tv seemed fine at first except HDMI ports 1 and 2 stopped working. Now after the tv warms up a little it turns off and then back on again all by itself and seems random. Seems a shame to get rid of the tv but I doubt it's worth getting fixed. I have a Fluke so I can check what needs to be checked. Hate to throw it away. Thanks for the help.
    Ivan
  • sordids999
    • May 2013
    • 2158
    • uk
    Re: Lg 60pv250
    worth a try i would say
    also:Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • im45us
      • Aug 2016
      • usa
      Re: Lg 60pv250
      I took pictures this morning and will post tomorrow when I get home. I turned it on this morning and after about 10 minutes it power cycles and then keeps cycling every minute or so. Picture looks great when the tv is on. I assume the main board because HDMI ports 1 & 2 don't work. But what controls the on - off because I think that's also a problem?
      Thanks Ivan
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8325
        Re: Lg 60pv250
        The HDMI ports go directly to the main IC. There is nothing much you can do, besides getting a new main board or replace the main IC.
        • im45us
          • Aug 2016
          • usa
          Re: Lg 60pv250
          I have looked online for the board. Can any one recommend a safe place to buy? Seems only repaired or used boards out there.
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            Re: Lg 60pv250
            You are only going to find used or repaired. They stopped making plasma tvs 3 years ago.
            Ptselectronicsinc.com may be able to repair yours.
            • SluggerB
              Panasonic TH-50PX80 killed by lightning strike, help me save her!
              by SluggerB
              Yes it's a 17 year old Panasonic plasma!
              I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
              06-04-2025, 07:02 PM
            • MrCreosote
              Lightning Strike: 55" TV dead: is display panel OK?
              by MrCreosote
              THE LIGHTNING:
              This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
              Very close and probably a very strong EMP.
              THE TV:
              No standby LED. Some voltage from PSB (not totally dead).
              But found a kit of ALL 4 circuit boards for $55.
              At first thought, this will fix my TV.
              But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
              08-16-2021, 10:27 PM
            • Highvoltagerchelie
              Sony XBR-65Z9D won't turn on after lighting strike
              by Highvoltagerchelie
              Good afternoon. I found this forum as I was looking for troubleshooting information for my Sony z9d. A lightning strike hit very close to the house and did nearly $30,000 in electronics damage. The TV appears completely dead with no status light and no picture. I found the Sony XBR-65Z9D service manual and followed the troubleshooting steps on Pages 21-26. All checks seem normal except DC_OFF_DET check on Page 23 R420 voltage was slightly higher than 3V. It was 3.475V and C418 was slightly higher that the 5V at 5.3V.
              I proceeded to check the Power Board CN6401 connector. With all...
              View and Download Sony XBR-65Z9D service manual online. GN2TR CHASSIS. XBR-65Z9D lcd tv pdf manual download.
              11-30-2023, 04:49 PM
            • karthur
              Samsung UN60EH6000 wont come on after lightning strike.
              by karthur
              We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
              I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
              When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
              Here is what I have checked.
              On the power supply board, 14pin connector:
              1 :12.7 Vdc
              3 :12.7
              5 :12.7
              7 :12.7
              9 :0
              11 :5.
              13 :5....
              11-01-2023, 06:18 PM
            • Bardou Kari
              HP EliteBook 840 G6 – no power after lightning strike
              by Bardou Kari
              I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
              – Charger is OK and 19V is present at the motherboard.
              – No charging LED, no fan, no reaction.
              – I don’t see any 3.3V or 5V near the coils.
              – Battery is unplugged.
              – I’m new to board repair but can use a multimeter.
              I added a clear photo of the board.
              Any idea where to start or what to check next?
              Thanks a lot for your help!...
              07-01-2025, 10:45 AM
